Carpet removal XK8 to enable footwell welding RESOLVED
Old Oct 3, 2012 | 01:24 PM
majoreyeswater's Avatar
Question Carpet removal XK8 to enable footwell welding RESOLVED
Hi, I have to weld some new plates into the Floor pan of my XK8 I will obviously need to remove the Carpets?.. Does anyone know the Secret of how to remove them without destroying anything important like the aluminum sill scuff panels? Thanks John
Popular Reply
Oct 3, 2012, 05:45 PM
The fixings for the Door Sill Treadplate (item 1) are concealed under the 'Jaguar - XK8' Insert (item 2):
The insert is glued in position. To remove it, warm gently to soften the adhesive and carefully start to prise up one end with a wooden spatula or thin plastic blade.
Once the end is lifted, insert a length of nylon fishing line and free the remainder of the adhesive using a sawing action on the line.
Take great care because it's very easy to distort the Insert.
Once the Insert is removed, release the three Paint Clearing Screws beneath to free the Treadplate.
Attached Thumbnails Carpet removal XK8 to enable footwell welding RESOLVED-xk8-door-sill-treadplate.jpg
Old Oct 3, 2012 | 05:45 PM
Attached Thumbnails Click image for larger version
Name:	XK8 - Door Sill Treadplate.jpg
Old Oct 3, 2012 | 06:54 PM
Nice one Graham
All good Major?
Old Oct 3, 2012 | 07:17 PM
WhiteXKR's Avatar
A hot air electric paint removal gun is the best tool for the job as GGG described above. Also if the nylon fishing line is too fragile, try using copper wire, about 22 or 24 gauge.
Old Oct 4, 2012 | 01:29 AM
XKRacer's Avatar
Seats and centre console out as well, when you lift the seats out pay extra attention to how you are doing it, very easy to catch the door and rear b post trim panel...
Also if you are interested I know a guy who is now making repair sections for the footwells to OE look with all the ribs but of course without the plate that caused all the probs in the first place!
Old Oct 4, 2012 | 04:39 AM
Thanks Guys, I will get started, I have already Purchased some Custom Made Panels from a Local XK8 Owner. Jaguar list nothing even the Main dealers are just talking about welding a plate under the existing rust?? A short term Bodge up it seems! But you are Heroes Thanks again..
Old Oct 7, 2012 | 03:43 PM
kingzetts's Avatar
Hey XKRRacer,
I'd be interested in the details of your contact who can supply the floor plates - my recently-acquired XK8 needs the usual footwell repairs!
Old Oct 8, 2012 | 03:05 AM
XKRacer's Avatar
His name is Lance and based in Kings Lyn his email address is lblcars@hotmail.co.uk let him know Tony from Paragon put you on to him and he will sort you out.
Old Oct 9, 2012 | 03:52 AM
kingzetts's Avatar
That's great, thanks Tony.
Old Oct 9, 2012 | 03:35 PM
Originally Posted by XKRacer
His name is Lance and based in Cornwall his email address is lblcars@hotmail.co.uk let him know Tony from Paragon put you on to him and he will sort you out.
The Guy I purchased mine from is:
B-L Models
Willow Farm Units,
Lynn Road, Saddlebow,
Kings Lynn
Norfolk
PE34 3AR
He also makes Jaguar XK8 Lower rear quarter panels hand made etched and ready to fit
He sells both items on ebay using the name: adammodels
Old Oct 9, 2012 | 09:52 PM
XKRacer's Avatar
Same guy He's not far away from me
Old Oct 10, 2012 | 06:44 AM
x-biker's Avatar
Old Oct 22, 2012 | 08:38 AM
Hi again, Any tips on removing the centre console to remove the carpets?
The Hot air gun and copper wire worked beautifully for the Sill Guard Thank you.
Old Oct 22, 2012 | 08:47 AM
WhiteXKR's Avatar
Old Oct 22, 2012 | 09:02 AM
Just when you thought you were finished with wacky tools like a hot air gun and wire, now you need a couple of credit cards to remove the shifter surround!
Old Oct 22, 2012 | 04:14 PM
XKRacer's Avatar
I beleive WhiteXKR has given you everything you need
Old Oct 22, 2012 | 04:15 PM
Jag#4's Avatar
How much credit needs to be on the cards to make this work properly?
Old Oct 22, 2012 | 05:04 PM
WhiteXKR's Avatar
Enough to buy one of these when you break the tabs
Mina Gallery: Aluminum Shift Gate for XK8 or XKR
Old Oct 22, 2012 | 05:23 PM
+1
It only took Jaguar three XJ saloon models and the XK8 4.0 litre to solve the rubbish plastic shifter surround design.
Old Oct 22, 2012 | 07:09 PM
Roadhogg's Avatar
Banned
Does anyone have any recommendations for someone that can do the welding as well?
This job is on my cars to do list as well, and after my problems with mechanical bits, i wouldn't fancy having to use a welding gun.
They'd have to evacuate the area before letting me near it.
I'm also wondering how a guy named Lance with identical email addresses, moved from Kings Lynn to Cornwall so fast
He must have an XKR.
