Cat purring sound when turning steering wheels
Old Jul 19, 2024 | 09:02 PM
Aleather's Avatar
Default Cat purring sound when turning steering wheels
A couple years and many miles ago, I was driving the xk8 under 55 degrees outside temp, and every time I "moved" the steering wheel I would hear a higher pitch cat like purring sound. The noise would go away when I stopped "moving" the wheel. Now today, it was about 80 degrees outside and the cat purring is back - only when steering wheel is "moving" left or right and gone when the steering wheel is not moving; even if I was stopped in park, any movement of the steering wheel would produce a sound, but holding the steering wheel still, in any position, stops the sound. The purring is coming from the steering wheel, not the serpentine belt (new) or the power steering pump (recently flushed). It did go away later in the day...
Old Jul 20, 2024 | 09:18 AM
MRomanik's Avatar
Veteran: Air Force
Check the PS fluid level. I had an Audi the did that and turned out it had a leaking PS hose.
Old Jul 20, 2024 | 11:39 PM
Y2KJag's Avatar
Classic low fluid symptoms.
Old Jul 21, 2024 | 08:55 AM
JACKP's Avatar
What could possibly be wrong with a Jag Purring like a cat?
Old Jul 21, 2024 | 11:06 AM
Aleather's Avatar
I just checked the fluid and it's fill right up to the top line. I know that fluid over that top line is considered over-filled. Sound is gone for now, but I know it will be back.... What should I look for when it does come back? There is no fluid leaks I can see, and fluid has always been good. Maybe it's the power-steering pump? At first, I thought, maybe a dried-up and/or defective bushing or spacer in the steering column, because sound is more coming from the steering wheel than the pump, but...???
Old Jul 25, 2024 | 09:00 PM
Y2KJag's Avatar
With the car running and the hood open, have an assistant turn the wheel while you listen to the pump area. Do you hear it when the wheel is turned right and left? A worn pump can sound a bit like low fluid.
Old Jul 25, 2024 | 11:05 PM
Addicted2boost's Avatar
I have seen nearly seized lower steering shaft U joints on these cars. You have to look for rust dust at the U joints themselves. I’ve also heard the steering shaft bushing make weird sounds. The lower steering shaft where it goes through the firewall, there’s a bushing in the middle that can make noises. Perhaps use some spray lube with the wand still attached to it to see if you can get anywhere with it.
Old May 27, 2025 | 06:13 PM
Aleather's Avatar
I found the noise when turning the steering wheel... It's that U joint inside the car, directly about the brake paddle. I strayed it with LIQUID WRENCH Silicone Spray and it goes away, but after a couple weeks it's back. The rubber inside the U joint looks really thick and good; What else can I spray on it to stop the noise for good without taking it apart?
Old May 27, 2025 | 07:29 PM
Tha Driver's Avatar
Liquid Bearings
Amazon.com: Liquid Bearings with Extra-Long 3" Needle, Pure Synthetic Oil for All Typewriters, Restores Sticky or Frozen Keys Amazon.com: Liquid Bearings with Extra-Long 3" Needle, Pure Synthetic Oil for All Typewriters, Restores Sticky or Frozen Keys
Absolutely best product I've found for lubricating small bearings & such. Stays in place longer than other oils/products. I use it on my HO scale slot cars, household fans, etc. If you can get it to (& into) the u-joint should solve your problem.
Old May 27, 2025 | 11:00 PM
zray's Avatar
Originally Posted by Tha Driver
Liquid Bearings
That stuff looks pretty cool. Have to admit I’d never heard of it yet.
Z
Old May 28, 2025 | 04:40 AM
I would personally use a silicone based oil because it won’t expand rubber like a petroleum based oil would. With the rubber expanding, I think it would potentially make it worse??
Old May 28, 2025 | 08:02 AM
Tha Driver's Avatar
Liquid Bearings is a 100%-synthetic lubricant...
Ojeii
Oct 26, 2022 06:51 PM
Wayne Lea
Jan 15, 2022 06:14 AM
Lovemycat88
Sep 28, 2019 03:56 AM
carzaddict
Aug 7, 2018 09:54 AM
Guernz
Dec 28, 2015 08:19 PM
