Central locking with key
Old Mar 21, 2026 | 04:12 AM
Zephyr's Avatar
Default Central locking with key
Hi all,
My security module is currently away for repair so I'm temporarily locking/unlocking the doors with the key. When I unlock, I can hear the central locking go through what sounds like an unlock-lock-unlock-lock-unlock cycle, is this normal? (2003 XKR)
Old Mar 21, 2026 | 04:34 AM
dibbit's Avatar
What you describe is normally a sign of a weak battery or a microswitch failing in the door latch mechanism, but given that you don't have the security and locking module installed in the car, I'm going to guess that the door lock status isn't being passed to the driver's and passenger's door modules anymore, so they think the doors are still locked after you have unlocked them, so it tries again a few times before giving up.
You could try pulling the fuse to the driver's door key barrel switches and see if that works as a temporary fix.
Old Mar 21, 2026 | 04:40 AM
Zephyr's Avatar
I fitted a new battery last week so it's not that. I'm just wondering if everything is spasming because the security module isn't there. It's still able to be locked and unlocked so it's no big deal, I was just wondering if it's a known thing. Cheers.
Old Mar 21, 2026 | 06:22 AM
dibbit's Avatar
I think running the car without the SLM is pretty unusual - you might be the first to document what happens when you do. Does the car actually work as normal otherwise?
Old Mar 21, 2026 | 06:54 AM
Zephyr's Avatar
Everything is normal, except for the fob doesn't work (obviously), the remote boot release doesn't work (need to use the key), and the fuel filler release doesn't work (need to use the emergency release in the boot). Also when I lock the door with the key I don't get the indicator flashes as there's no alarm.
Old Mar 21, 2026 | 11:22 AM
dibbit's Avatar
Talking of indicators, I suppose they and the fogs are the only rear lights that work, as everything else goes through the SLM.
Old Mar 21, 2026 | 11:39 AM
michaelh's Avatar
^^ +1
I'd expect no tail, stop or number plate lamps...
Old Mar 21, 2026 | 11:50 AM
Zephyr's Avatar
The garage certainly didn't mention that, I'll check tonight.
Old Mar 22, 2026 | 03:18 AM
Zephyr's Avatar
Yep, you're right. Rear indicators and high-level brake light only. Very annoying.
Old Mar 22, 2026 | 03:30 AM
dibbit's Avatar
And no check lights message on the dashboard as the module isn't there.
Old Mar 22, 2026 | 03:33 AM
Zephyr's Avatar
Nope, no messages or lights on the dashboard at all. If it weren't for the unlock-lock-unlock-lock-unlock cycle you'd never know. Apart from the rear lights, obviously.
Bill Mac
Jun 8, 2025 02:53 PM
Samdalo
General Tech Help
Aug 25, 2023 01:19 AM
XJ8Lou
Nov 23, 2016 12:52 PM
MJG
Dec 8, 2012 04:07 PM
driver safz
Jun 6, 2011 02:16 PM
