Change ignition switch barrel
Old 08-13-2021, 12:56 PM
phobman's Avatar
Default Change ignition switch barrel
Does anyone know what is involved in changing the ignition switch barrel in my 2002 XK8, It is getting difficult to turn and unreliable. Do I need to change the exciter ring to suit the new lock and key, or can the new key be reprogrammed to the old key, and who can do this kind of work? I'm in Southern California. I know how to physically change the barrel, just don't know how to make it work!
Old 08-13-2021, 01:14 PM
Received 7,925 Likes on 4,788 Posts
The dealer can order a replacement lock assy (if they are still available?) with the correct key code and the original keys should still work.
If you change the lock barrel with a different TIBBE cut then the replacement keys need to be configured to the car.
Did you try your other keys to see if they fit and work better??
Old 08-13-2021, 10:04 PM
phobman's Avatar
I only have the one key!
Old 08-14-2021, 08:04 AM
The following 2 users liked this post by motorcarman:
dfbender (08-14-2021), RJ237 (08-14-2021)
drbill
23
09-29-2022 11:49 AM
KrazyKGB
09-27-2019 02:15 AM
Valkyrie
01-20-2016 02:14 PM
berlin1977
11-08-2013 10:04 AM
john_cook12
02-10-2013 10:47 PM
Quick Reply: Change ignition switch barrel
