Changed fuel filter and can't believe the crud that came out!
Old Apr 12, 2015 | 10:47 AM
DougBoost's Avatar
Default Changed fuel filter and can't believe the crud that came out!
I finally tackled the replacement of the fuel filter in our 2006 XK8 Victory Edition convertible. We had been getting periodic lean codes on both banks and sometimes restricted performance messages. But you could clear them and they would usually stay away for quite a while. Still, I knew that was the original fuel filter and at 60K miles, and more importantly a~9 years, it was way overdue to change.
I had tried to do this job several months ago but after jacking up the left rear wheel and seeing how stupid this was put it off. I've been working on cars for 30 years and am with others on this forum who curse the engineer that put the filter where he/she did. But I now have a 4 post lift and it was much more manageable.
In all my years of working on cars I have never seen the gunk that came out of this filter when I dumped it out the reverse flow in my drain pain. All this dark gray sludge just kept pouring out!
I worry that maybe our fuel pump is disintegrating. Yet the gas that was dripping after removing it looked normal and so far the car still runs fine. Another thought was perhaps the previous owner added some sort of fuel additive at one point and it all ended up in the fuel filter?
I guess we'll see what happens next but thought I'd share that with this group and see what the collective experience and wisdom of everyone is.
Thanks,
Doug
Old Apr 12, 2015 | 10:57 AM
multiplecats's Avatar
Very interesting Doug,
As a matter of interest did you ever get a chance to measure the fuel-line pressure before you replaced the filter?
It would be interesting to note the difference after you changed it.
Andrew
Old Apr 12, 2015 | 12:19 PM
DougBoost's Avatar
Andrew,
No, I didn't go to the trouble to try and hook up a fuel pressure gauge, especially since I knew that fuel filter needed to be changed regardless. That said, I couldn't find a port anywhere on the fuel rail of the engine to relieve the pressure, which is also where you would connect the gauge (most cars have a Shraeder valve for this).
Do these engines have one and I just missed it?
Doug
Old Apr 12, 2015 | 12:56 PM
Jon89's Avatar
I changed the factory fuel filter (dated April 2005) on my wife's 2006 XK8 Victory Edition several weeks ago as part of my 90,000-mile service on her car. It dribbled several ounces of grey, murky gas as well. No doubt that the fuel pump was having to work extra-hard to force gas from the tank to the fuel rails. The car was running fine, though....
I guarantee you I won't wait nearly as long to change the fuel filter next time. Probably a good idea to change it every 30,000 miles or so. I suspect this would help to protect the very-difficult-to-access (and very expensive) fuel pump....
Old Apr 12, 2015 | 01:41 PM
Originally Posted by DougBoost
Andrew,
Doug
I would have thought it would have had a Shraeder valve somewhere. Mine is 2003MY which most definitely does have one, but can't comment on your MY.
I'm sure someone will be along soon with the relevant info.
Andrew
Old Apr 12, 2015 | 06:07 PM
DougBoost's Avatar
Andrew - can you tell me where it is exactly on your car? Extra credit for a picture .
I know my daughter's 2004 Mazda6 3.0 V6 (same engine as Jag V6's and later Fusions) had a Schraeder valve and they were removed by 2006 when they redesigned the fuel rail slightly. Not sure if that was a cost reducing move or what by I suspect that may be the case here. Learned more than I ever want to know about that engine when I had to replace it last year due to pre-cat failure (swapped in a 2008 Fusion engine, after swapping oil pan, front cover, valve covers, etc.). Decent engine (Porsche/Cosworth design) with a flawed exhaust system design by Mazda.
Doug
Old Apr 12, 2015 | 06:38 PM
From another post, don't know if it'll help or not but worth a shot?
The Schrader Valve on the 1999 XK8 is at the rear of the Right Fuel Rail:
Old Apr 12, 2015 | 07:01 PM
plums's Avatar
How many miles do you think the filter had on it?
It's odd that Jaguar uses such small filters on high output engines.
The BMW filter is a bit larger in diameter, but almost a foot long.
Old Apr 12, 2015 | 09:13 PM
Nookieman's Avatar
Were these cars with the dirty filters fueled with Ethanol blend fuel?
The reason I ask is because of the nasty appearance of the filter contents. The usual crud I have seen in fuel filters is rust or sand. I have seen ethanol dissolve fuel lines and plastic fuel tanks, both of which produced a nasty gel when they failed.
Old Apr 12, 2015 | 11:15 PM
ccfulton's Avatar
Some of the very early 4.2L engines have a Schrader valve but most do not. Some nonsense about reducing emissions.
In this case, all you have is the electronic sensor to go by.
Old Apr 13, 2015 | 07:48 AM
Here's the Schrader valve on my 2004MY 4.2 (engine cover removed):-
Surprised they did away with it, but then electronic sensors never lie do they?
Andrew
Old Apr 13, 2015 | 08:28 AM
aode06's Avatar
https://www.jaguarforums.com/forum/x...crisis-104680/
my horror story
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
Sprayall
Sep 3, 2015 07:49 PM
pnwrs2000
Sep 3, 2015 11:55 AM
