check engine light
Old Jan 4, 2014 | 01:31 PM
stevepaa's Avatar
Default check engine light
yesterday had a rough idle when cold and misfires on 1,2,4,5,6 cylinders. I changed plugs and secondary tensioners last year and used NGK BKR5EIX-11. Pulled number 5 today and there was baked on oil at the insulator interface. Could this leakage cause misfiring?
Old Jan 4, 2014 | 01:33 PM
avt007's Avatar
Check out this link- PLUG STUDIO / NGK
Old Jan 4, 2014 | 01:44 PM
stevepaa's Avatar
thanks. I guess I'll swap in some coil packs I have and see what happens.
Old Jan 4, 2014 | 02:29 PM
WhiteXKR's Avatar
Steve, clear the codes and check the codes right after starting and continuously thereafter untii the first misfire code appears.
Under some fault conditions a single failed coil can cause multiple cylinder misfires, but it usually shows up as the first code registered on OBDII.
Old Jan 5, 2014 | 01:24 AM
stevepaa's Avatar
Steve, thanks. That is interesting. The misfire was so infrequent that it was days between occurrences. I changed out 2 of the 5 coils and will see what happens.
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
