Chrome shifter surrounds
Old Oct 27, 2010 | 06:17 PM
yyk's Avatar
yyk
Default Chrome shifter surrounds
Hey guys,
Are these chrome surround pieces designed to be installed with screws, or are those fake cut-outs? If not is any drilling necessary? How about the switches?
2000 XKR
Old Oct 27, 2010 | 07:01 PM
Jaxkr's Avatar
They screw in, the switches are mounted from the underside with a bracket. If you want a good deal on one I have two differnt styles for sale that are in good condition, the factory one & also an Adamesh , both in polised aluminum.
Old Oct 28, 2010 | 09:27 AM
yyk's Avatar
yyk
Default shifter surround
I've seen some chrome pieces, the bracket is just a square piece underneath that I gather holds the switches. Does this square bracket hold the switches and cables snugly? And are there cut-outs ready in the plastic underneath for the screw threads to fasten in?
yyk
Old Nov 2, 2010 | 09:43 AM
yyk's Avatar
yyk
Default Chrome surround bezel
I installed one. Had to remove the brass metal hold downs for the plastic wood. Cleaned that all out. Detached the switches carefully and removed the shifter knob.
On the new chrome bezel I needed to remove the included bracket for switches completely. Placed the switches in their correct slots, and then slowly torqued down the bracket. Completely tightening these small screws will cause the switches to freeze and not move in their full travel, so I had to loosen the bracket until I could get them to fully click on and off.
The kit included a new key fob and 4 nice chrome air-valve screw caps for the wheels.
adam699
Oct 13, 2015 05:53 PM
Johnken
Oct 2, 2015 10:12 AM
Johnken
Oct 1, 2015 05:07 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
