cleaned throttle body now Codes!
Old Aug 28, 2013 | 01:30 PM
killergsxr1's Avatar
Default cleaned throttle body now Codes!
..my car was running perfect with no lights and codes...it was time for a tuneup so i started with looking to see if the throttle body was dirty..it was alittle so i sprayed some throttle body cleaner in there let it soak for 1 min,sprayed alittle more and all looking very clean so i buttoned hear up waited an hour and started her..it now runs rough and has a red light with limited performance on the dash...pulled codes(high end reader) and got p1226 and a description..does that mean a very small amount of throttle body cleaner ruined my throttle body and now i need a new one????
Old Aug 28, 2013 | 02:32 PM
test point's Avatar
The P1226 is an unusual code that apparently applies only to early, '96-'98 cars and is associated with the Throttle Body.
Here is a link to an earlier discussion but it does not provide a clear answer: https://www.jaguarforums.com/forum/x...lt-code-27747/
Please add your car model and year to your signature to help us as the vehicles evolved over the 10 years of this model's production.
. . . . and welcome to the forum.
Old Aug 28, 2013 | 05:18 PM
WhiteXKR's Avatar
Try a hard reset and see if it clears.
The mechanical guard is explained in this document:http://www.thejagwrangler.com/upload...c_throttle.pdf
Old Aug 28, 2013 | 05:38 PM
As has already been stated, code P1226 applies only to early XK8's. Here is the list of possible causes (see middle column):
It's some coincidence to develop a harness or sensor fault just after cleaning the TB. Assuming no physical damage to the guard spring during cleaning, probably you've been a bit over enthusiastic with spraying the cleaner.
A hard reset may clear the code. If not it will have to be cleared with a scantool.
Old Aug 29, 2013 | 02:23 PM
well i got the code to go away..i removed the intake tubing,inspected for leaks,found none and its in really good shape.reassembled everything and codes went away..but she is idleing very rough at idle..anything over idle its smooth as can be and has great power but idle is very rough..thoughts?
Old Aug 29, 2013 | 04:27 PM
test point's Avatar
Have you cleaned your Part Load Breather orifice?
Old Aug 30, 2013 | 08:57 AM
is that in the little tube going from the intake pipe to the valve cover?? that little tube was broke when i got it so i replaced it..but there nothing in it..and the nipple on the valve cover has nothing in it aslo,is there supposed to be??got a pic i can see of what your talking about?
H20boy
Dec 24, 2024 03:23 PM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
OkieTim
Sep 2, 2015 12:48 PM
