Clear Code P1582
Old Sep 5, 2024 | 06:06 PM
IanDmm's Avatar
Default Clear Code P1582
I am trying to clear the code P1582 (Flight Recorder Data Is Stored). I am very confident that it developed from “engine starts and stumbles”. I am using a Foxwell OBD2 reader but am not sure how to clear this fault code.
If anyone could help with this it would be very much appreciated.
Old Sep 6, 2024 | 04:03 AM
dibbit's Avatar
Why do you need to clear it? It's only to indicate to an engineer that there is troubleshooting data available.
Is there a Vehicle Configuration menu in your reader? The code can't be erased in the normal way, you need to go into that menu.
Old Sep 6, 2024 | 08:14 AM
Theo14's Avatar
I have the same code, but not too worried about it. I believe you may need the Jaguar IDS to be able to clear that one.
Old Sep 6, 2024 | 09:02 AM
motorcarman's Avatar
P1582 = EDR (Engine Data Recorder)
Can only be cleared by reading the 37 frames of the 'EVENT' in the ECM and then the PDU/WDS/IDS will ask if you want to delete the info.
Old Sep 6, 2024 | 05:39 PM
IanDmm's Avatar
Thanks lads for the feedback.
I have been working on this system for only a short time and still trying to get my head around some of the information and acronyms.
Motorcarman, would you please be able to explain your paragraph a bit clearer for a novice on the system.
"P1582 = EDR (Engine Data Recorder)
Can only be cleared by reading the 37 frames of the 'EVENT' in the ECM and then the PDU/WDS/IDS will ask if you want to delete the info."
Old Sep 6, 2024 | 08:21 PM
When P1582 DTC in logged in the ECM, there is DATA logged for some EVENT. (engine stall, sensor failure, mechanical failure detected etc.)
You can read the 37 frames of the EVENT up to and including all the engine parameters (engine temp, RPM, MAF, vehicle speed etc.) leading up to the EVENT as well as 2 frames AFTER the EVENT.
This is usually only about 2 seconds of data, but the ECM is continually recording the engine data until the EVENT and there are 2 recorders, A and B as well as a start time reliability. (I think that is the nomenclature used?)
The EDR can be accessed with WDS/IDS in the SETUP and CONFIGURATION tab.
Old Sep 7, 2024 | 02:20 AM
IanDmm's Avatar
OK, thanks Motorcarman for the feedback, I will take another look at it.
Old Sep 7, 2024 | 07:37 AM
JagV8's Avatar
Usually it's ok to ignore that code. It won't cause problems.
innzane
Apr 21, 2015 10:08 AM
Spikepaga
Dec 4, 2014 01:34 AM
daboss085
May 22, 2012 09:43 PM
nickpc2001
Feb 23, 2011 04:26 PM
test point
Sep 29, 2010 10:21 PM
