clicking noise...
Old Jan 14, 2013 | 11:51 AM
flydutch's Avatar
Default clicking noise...
Hi everyone-
I have an '03 XK8 convert. I saw a thread last year about steady (no change with rpm) ticking noises coming from the left fender cowl behind the front wheel well. It sounds like a solenoid clacking. It comes for a few minutes and then goes away, quite intermittently. It was very cold in St. Louis yesterday and it was louder than usual, it seemed. Any observations? Thanks.
Old Jan 14, 2013 | 12:27 PM
danielXKR's Avatar
Hi,
There is a TSB (303-62) that seems close to your description. Title is "Ticking Noise from left side footwell-EVAP Canister Purge Valve"
Model range 2003-05 MY XK Range VIN A30645-A40920
I have changed my Purge Valve last week "after I can say" a long story about a gearbox fault (too long to explain here).
Changing this valve is very easy and well described in the TSB. The cost is about 80€ for the valve.
Daniel
Old Jan 14, 2013 | 12:42 PM
flydutch's Avatar
Thanks Daniel ! That definitely rings a bell and I will go look at the TSB. Cheers!
boiler
US Southwest
Dec 20, 2025 12:38 AM
magmedia
Oct 8, 2015 03:28 PM
gunlocators
Sep 30, 2015 08:05 AM
bydand
Sep 28, 2015 09:47 AM
Long Islander
Sep 27, 2015 03:45 PM
