Code 1260
Old Mar 27, 2021 | 10:01 AM
Vincente Fortes's Avatar
Default Code 1260
Hello jag. World
can any tell me how to reset code 1260. The alarm sets and turns off with the key. I can lock and unlock the doors and the trunk. It came with a alarm pad but it doesn't work. It will not go into key pad program mode.
Thanks and any help will be appreciated.
Old Mar 31, 2021 | 02:36 PM
PKWise's Avatar
Hello Vincente,
There are many potential causes to your problem. Some could be due to the key-fob remote signal transmission (Battery or Fob Version) and others can be due to the car signal receiver (Antenna or Security Module).
The first easy thing to check is that the Antenna ‘Aerial’ Coax cable joint is screwed into the security module and undamaged. The Security module sits behind the Battery in the trunk/boot and the Coax terminal is protected by a ‘Bollard’ as described in this short video by John ‘To The Garage’.
Check that the cable joint is not loose. If there is play, even when tight, then this could be damaged and will need fixing first because no signal can be received.
Old Mar 31, 2021 | 03:30 PM
motorcarman's Avatar
The KTM is NOT recognizing the RFID transponder in the key.
Basically, your key is NOT recognized and car is immobilized.
Try another key. (please don't say that you only have ONE KEY)
Every once in a while I see that DTC and I even have to turn my key twice to get the engine started.
Maybe I just turn the key too fast for the transponder to react?
File Type: pdf
XJExecutive
22
Jul 12, 2013 12:31 PM
emitcomputer
Sep 30, 2011 07:20 PM
rgun2515
Oct 30, 2010 06:07 PM
