Coil Wire Cut
Old May 27, 2014 | 07:17 PM
Kalahari's Avatar
Exclamation Coil Wire Cut
Ok, so I apparently pinched and cut the black wire going to the #8 coil pack. Can this be repaired or do I need a new harness? I have enough wire to make a repair if that is possible.
Old May 27, 2014 | 07:19 PM
WhiteXKR's Avatar
You can repair it, but it would be best to solder in the repair and cover it with heat shrink tubing.
2001 White XJ8
Feb 25, 2021 05:02 PM
copyman01
Nov 1, 2015 01:01 PM
andyw
Sep 26, 2015 01:59 PM
Dicque
Sep 19, 2015 12:53 PM
Bones
Sep 8, 2015 08:34 PM
