Cold Start Power Steering groan
Old Mar 3, 2016 | 04:20 PM
Jag#4's Avatar
Originally Posted by scardini1
My turkey baster is actually bought "for" the garage. I have to search it down on the rare occasions it's needed in the kitchen. My funnels and little Tupperware containers are the same way. I long ago realized I wasn't using "kitchen things" every once in while on the cars, .... it was the REVERSE. So now, the garage is their primary home. It's just one of the advantages of having to deal with girlfriends vs. a wife - lol.
OR, it's the best way to end up with a girlfriend vs. a wife.
Old Mar 3, 2016 | 04:27 PM
Jag#4's Avatar
BTW, I have now pulled out and replaced about 3/4 quart of brown sludge. So maybe 1/2 of fresh fluid in there now due to mixing.
The groan is 90% gone. I'm going to do this one or two more times, hopefully making it go away completely.
I am convinced if you were to pull the lines and drain it properly, it would be a better fix. I was just nervous about touching those connections and causing a leakage problem. Plus the baster method is easier... and I am generally lazy.
Old Mar 7, 2016 | 08:48 AM
Brutal's Avatar
Originally Posted by Jon89
Brutal,
The key is to swipe those kitchen tools while the wife is away, immediately use them as needed, clean them thoroughly, and put them back exactly where they belong before she has a chance to return home....
Her tooth brush works well on cleaning throttle body as it wont remove coating only carbon
Old Mar 7, 2016 | 03:43 PM
giandanielxk8's Avatar
I changed the p/s oil on mine and the groan was still there. I ordered a new pump and am waiting for it to arrive.
Old Mar 8, 2016 | 07:33 AM
scardini1's Avatar
How many miles do you have on the car/pump?
Old Mar 8, 2016 | 01:36 PM
87,800 miles
The power steering leak is coming from the pump and I can see its landing on the belt and tensioner as well as on the garage floor. Even if a change of gaskets solves the leak, a new pump gives me peace of mind.
Old May 20, 2019 | 10:23 AM
scottatl's Avatar
Originally Posted by Brutal
doubtfull you have every changed the fluid cause most people think the only thing that gets old and dirty is oil. neglecting PS, trans, diff, brake fluid and coolant leads to shorter life and other issues down the road. Soooo drain the fluid and refill with synthetic. I like Mobil1 syn ATF. You dont have to flush just drain most out. I do this by taking out the torx bolt holding the 2 PS lines in at the rack, reservoir cap off and drain the system. While up rotate the tires left and right till all the fluid is pretty much pushed from the rack. Hook lines back fill reservoir to top, start the engine for a second then top up again and restart letting run and fill a neccesary. This was always Jaguars solution to PS noises and works well in most cases.
Does anyone have a picture of where this torx bolt is or a good way of explaining how to find it. This seems to be the way to go.
hugh ness
Feb 27, 2016 02:49 AM
cyber3d
Feb 11, 2016 08:18 AM
giandanielxk8
Feb 10, 2016 06:45 AM
michaelodonnell123
Feb 5, 2016 07:19 AM
xjsman89
Jan 29, 2016 10:05 AM
