Confused with these part numbers
Old Feb 8, 2019 | 04:13 AM
giandanielxk8's Avatar
Default Confused with these part numbers
Hi, I noticed that there are two versions of the following parts: tie-rod ends and front lower control arm ball-joint, for an ‘04 Jaguar XKR.
Can anyone confirm that these part #s fit my car:
MNC1350AA - Ball joint
JLM9660 - Tie Rod
Which of these is the correct steering rack mounting bush?
MJB3953BA
MJB3953AA
MJB3953AC
Are the the ones sold by Welsh OE or aftermarket?They seem to be rather inexpensive.
Old Feb 8, 2019 | 05:50 PM
If you check SNG Barratt's site - JLM 9660 has been superseded but it will fit your car https://www.sngbarratt.com/us/#!/Eng...6-424bbf37fd7b
MNC1350AA doesn't list applicable models
MJB3953AA/BA both show they cover from VIN 024687 through the 2002 MY and MJB3953AC comes up no match
Here is the link toe the SNG catalog for 2002-2006 MY https://www.sngbarratt.com/us/#!/Eng.../47/all/1/10/1
Steering rack bushings are MXD3953AA/BA for driver/passenger sides https://www.sngbarratt.com/us/#!/Eng...20AND%20PINION
Old Feb 8, 2019 | 06:10 PM
Thanks! I found most of the P/N you list on Welsh’s site, they are less expensive there.
Oddly enough, SNG Barratt doesn’t list a ball joint for the lower control arm.
Got any ideas?
Old Feb 10, 2019 | 06:46 PM
Hdpartsman00XKR's Avatar
I found my lower ball joints at Christophers Foreign Car Parts, part #350596986962, paid $97.90 for them both several years ago. Can't remember if these were Lemforders, but they were made in England.
3/16 plate, 2 pcs angle iron, 2in tubing,20 ton press, balljoints are in!!!
Had to make my own jig so to press them in, but was well worth it! Hope this helps.
Cheers, BK
Old Feb 12, 2019 | 10:19 AM
SNG Barratt USA's Avatar
Former Sponsor
The lower balljoint is part number MNC1350AA. See link below, the # vversion is made by Lemforder (Original)
https://www.sngbarratt.com/us/#!/Eng...#resultsAnchor
Old Feb 12, 2019 | 05:09 PM
Thank you very much!
Old Feb 12, 2019 | 05:15 PM
don't forget - SNG offers forum members a discount
JaguarXKR
Feb 14, 2017 09:02 AM
XKE66andXK8
Oct 14, 2011 11:13 PM
SC Guy XK8
May 27, 2010 09:12 AM
bekcon
Dec 10, 2008 07:54 PM
mr.xtype
Feb 25, 2008 12:45 PM
