conv hydraulic hoses
Old Feb 22, 2011 | 05:39 PM
stevepaa's Avatar
Default conv hydraulic hoses
Fortunately, the PO replaced the latch hoses in 2007 and the chain tensioners
I have added the pressure reducer, should I replace the cylinder hoses at this time?
thanks
Old Feb 22, 2011 | 06:43 PM
WhiteXKR's Avatar
My cylinder hoses show some signs of deterioration (outer sheathing soft, peeling away in a couple of spots). At $400-500 for a repalcement set, I have decided to just keep a watchful eye for now.
Unlike the latch hoses, it is not a danger to spray in your face while drivng, and you can always close the top manually in the case of failure. So I see little risk in waiting until they actually fail.
Old Feb 22, 2011 | 06:44 PM
test point's Avatar
If you do not have an identified leak and have installed one of the pressure reducing solutions I would forget it and enjoy the car.
Old Feb 22, 2011 | 07:09 PM
Reverend Sam's Avatar
What they said. I don't recall ever hearing of a cylinder hose bursting. Even leaking cylinder hoses are rare. They don't get the super-high pressure that the latch hose receives.
Old Feb 22, 2011 | 07:29 PM
Gus's Avatar
Gus
If it is the hose to the lifts (on the fender side of the pump) they may leak but have not seen one fail. If it is the hose set to the roof latch (the trunk side of the pump) you would be correct in working towards replacement. If it is the hose to the roof installing a pressure system of any type will only prolong the inevitable. Replace the hose!
Old Jun 27, 2012 | 05:03 PM
wlbusmcr's Avatar
Gents;
Working on replacing my convertible top hoses at the cylinders.
How do you get the bottom hose off of the right cylinder? There is no pipe to tube elbow...it looks like a small piece of tubing that runs right from the hose into the blind end of the cylinder.
Also trying to figure out what the black and white stiff wires are under the right quarter cap in the back. It almost looks like a thremocouple. Any ideas?
Thanks,
Bill
Old Jun 27, 2012 | 07:56 PM
Gus's Avatar
Gus
I am not sure what it is you are looking at do you have photos?
Originally Posted by wlbusmcr
Gents;
Thanks,
Bill
Old Jun 27, 2012 | 09:52 PM
wlbusmcr's Avatar
Default response to yours.
Gus here are the pictures.
Can't figure the one with the red and white arrow. It almost looks like a thermocouple.
The one with the black and white arrow is the hydraulic line feeding the blind side on the right cylinder.
Thanks,
Bill
Attached Thumbnails conv hydraulic hoses-img_0287.jpg   conv hydraulic hoses-img_0288.jpg
Old Jun 27, 2012 | 10:06 PM
Gus's Avatar
Gus
I have seen this but not had reason to fool with it so I am not sure how to remove it. I think is has a type of “C” clip holding it is place. As for the wire I am not sure of the colors but you should have 2 leads to the ram on the right used to determine when the ram is extended or retracted. They tell the computer to control the pump operation for up, down and the latch operation. Whatever you do, do not damage them.
Old Jun 27, 2012 | 10:26 PM
WhiteXKR's Avatar
Thanks,
Bill
Bill-
The wire is the antenna for the remote. It connects to the Security and Locking Module in the trunk under the fusebox.
I believe the entire fitting unscrews from the brass colored base of the cylinder. You may have to remove the cylinder to get access. I have not actually done it, so not 100% sure.
Old Jun 30, 2012 | 08:07 AM
jagjer55's Avatar
i was wondering what that gizzmo was myself
Old Jun 30, 2012 | 08:10 AM
jagjer55's Avatar
does anyone have pictures or instructions for hooking up the new braided hoses for the top latch?
Old Jun 30, 2012 | 08:59 AM
Did you check Gus's how to?
JagRepair.com - Jaguar Repair Information Resource
Old Jun 30, 2012 | 10:52 PM
wlbusmcr's Avatar
Well I done gone and did it. I lost the marking to all the hoses and to where they went. The hydraulic cylinders were bad, leaking at the packing gland, got them fixed. Also got SS braid hoses for $28.00/line but lost the labeling of which port on the pump they hooked up to. Any body have a schematic or layout?
I do have a fix though to convert to #4 JIC flare on the tees using a 5/16" flare nut, tapping the one end for 7/16"-20 UNF and running a 1/4" tube union down tight into the flare nut.
Thanks for your help.
Bill
Old Jul 1, 2012 | 11:02 AM
Gus's Avatar
Gus
Top hose at latch to top hose on pump! READ MY PAGE! all that information is on it.
Old Jul 2, 2012 | 09:08 AM
jagjer55's Avatar
i found the page on replacing the hoses with original ones. i bought the kit with the ss braided ones with replacement fittings. just wanting to find out which fittings go where. nothing came in the kit giving a diagram.
Old Jul 10, 2012 | 09:33 PM
polska2's Avatar
Cool location of cylinder hoses on pump
my top forward fender side cylinder hose burst out of its crimped connection. Trying to find out if that is the left or right set of hoses before ordering.
Old Jul 11, 2012 | 11:41 AM
wlbusmcr's Avatar
Default top hoses
Check JTIS they have a diagram of what goes where.
I did post it on this forum also.
Looking at the "T"s on the pump/tank combo with tank on left,
Left side of the "T"fittings, left, drivers side
Right side of the "T" fittings ,right, passenger side
Hope the helps.
Bill
mikiep
Dec 20, 2019 07:37 PM
Sonnyblack
Oct 4, 2015 05:42 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
