CONVERTABLE TOP HELP
Old Jul 22, 2008 | 11:59 AM
lcyoung's Avatar
Default CONVERTABLE TOP HELP
I JUST BOUGHT A 2003 JAGUAR XKR. AND LAST WEEK MY AIR HOSE BUSTED ON MY TOP. THEY CHARGED ME $1250 TO FIX. NOW THEY SAYING MY AIR PUMP GONE BAD.. AND IT COST $2000 FOR THE PUMP AND $500 TO FIX IT. THEDEALER CHARGE TO MUCH.IT WONT LET MY LATCH ATTACH AND IT WONT LET MY TWO BACK WINDOWS RISE UP.. I TRIED MANUALLY LATCHIKN IT BUT THE LAST OWNER STRIPPED THE HOLE... I NEED HELP..LOL.. BUT I DO... ANY ONE WITH SUGGESTION
Old Jul 22, 2008 | 10:24 PM
GordoCatCar's Avatar
Default RE: CONVERTABLE TOP HELP
Buy a used or rebuilt pump and put it in yourself. Otherwise take your car to an independent Jag expert. Dealerships are not the place to get your top or pump fixed.... As you are finding out. gordo
PS: Lose the CAPS
Old Jul 23, 2008 | 12:22 AM
lcyoung's Avatar
thanks gordocatcar.. but where can i find one and anyway of findind out how to put it on
Old Jul 23, 2008 | 07:42 AM
test point's Avatar
I found one by searching for used auto parts. Paid $150 after several at up to $800.
Check the by-pass valve and fluid level first.
Old Jul 23, 2008 | 10:19 AM
lcyoung's Avatar
test point can u tell me where the pump, by pass valve and fluid level located
Old Jul 23, 2008 | 11:50 AM
In the trunk, on the right hand side, behindthe pull out panel.
Old Jul 23, 2008 | 04:55 PM
test point's Avatar
I've lost three long posts trying to address your issue. Kicks me completely out of the site.
Anyway, hopefully you have found the pump by now. By-pass valve is the brass 'T' handle on the trunk side of the pump body. Closed is clockwise. You want it closed. Open is for manually raising/lowering top. Check fluid level also. Should be about an inch from the top. It is marked but difficult to see.
If you really have a pump problem, which I do not believe you do, I have one I will give you for the shipping charges. It has a bad solenoid due to a previous owner tearing off the electrical connector and will require your reservoir as the used one I bought leaked.
Old Jul 23, 2008 | 07:31 PM
lcyoung's Avatar
the fluid is like three inches from the bottom of the reservoir.. can this be on e of the reason the latch wont lock....
Old Jul 23, 2008 | 07:59 PM
test point's Avatar
Way too low!
The two horizontal lines on the side of the reservoir are the MAX/MIN fill lines.
If you paid someone to fix the top latch they should have left the reservoir properly filled. Otherwise, Pentosen CHF 11S hydraulic fluid available at NAPA for $17 a liter. Fill with a turkey baster from the Dollar Store and $0.50 of plastic tubing from a hardware store. Requires a small diameter tubing.
Spelling
Old Jul 23, 2008 | 09:38 PM
lcyoung's Avatar
this can cause the latch from locking test poiint.. did u see the picture i attached to the message
Old Jul 24, 2008 | 05:18 AM
test point's Avatar
Yes, I saw the picture and the fluid level is way too low! Might not be the problem but should be corrected first to eliminate the issue. Any signs of leaking oil?
Old Jul 24, 2008 | 09:41 AM
lcyoung's Avatar
seem like its leaking oil.. on the driver side right by the code reader.. at first i thought it was somthing they forgot to clean up... and can that hole where u manually latch the top down.. be fix cause its stripped out...
Old Jul 24, 2008 | 01:29 PM
hlgeorge's Avatar
That hydraulic line goes down the driver side behind the fuses, so it is very likely that the leak could show up around the OBD2 port. If you are not familier with the top hydraulics, I suggest you take it to a repair shop that has experience with them.
Old Jul 24, 2008 | 03:00 PM
Gus's Avatar
Gus
Go to my web page and select Roof Hose Repair and see if that helps.
Old Jul 25, 2008 | 08:57 AM
Hi Gus. Thanks for your pics on the top hose replacement. As you can see this is a common problem and anyone wanting to replace the complete hose should view your photos before beginning the project. BTW, I am beginning to think total replacement is a much better fix. This thread is case in point. He notes the leak is in the general area of the splice. I would not be surprised if the splice itself was the problem Hopefully he only needs to tighten the couplings.
Did you resolve your Restricted Performance warning text?
Gordo
Old Aug 17, 2008 | 02:51 PM
Gus's Avatar
Gus
Yes Gordo I did get it resolved. I put the story on my page. How is the hose going?
FrickenJag
Jun 16, 2025 02:15 PM
1100me
Jul 24, 2023 06:10 PM
Rivguy
Dec 4, 2020 07:55 AM
1100me
Sep 7, 2015 06:26 AM
jfitzoz
Sep 7, 2015 04:28 AM
