Convertible question
Old Apr 14, 2021 | 01:40 PM
DavidYau's Avatar
Default Hydraulic Pump is electrically driven
As the hydraulic pump is electrically driven, with the car engine off, the power comes direct from the battery. This source is less powerful than the engine’s generator/alternator so using the battery would put less pressure in the hydraulic fluid, so it’s marginally less likely to cause leaks. There’s not much in it.
If this is the principle concern there’s a simple cheap electrical resistor fix (check out Rev Sam’s great video) that will do the same trick.
Bear in mind all hydraulics parts age, not just hoses, ie gaskets, seals etc. In the extreme heat of the Middle East, we have to service the hydraulic fluid more frequently as it tends to gum up.
Old Apr 15, 2021 | 12:28 AM
CA Jag's Avatar
Any suggestions for aftermarket hoses? Stainless steel would be nice.
Old Apr 15, 2021 | 01:31 AM
Old Apr 18, 2021 | 07:02 AM
GregCPX's Avatar
Originally Posted by SamtheSham
Just had my hoses replaced. Costs with me buying hoses, $1800. Will try raising without the engine running. Di not have "Green Shower" Had leak in windshield side hose.
Did you replace yourself or have someone do it? Just kind of curious?
DJoli
Aug 24, 2020 10:54 AM
Oldelance
Jul 8, 2020 01:43 AM
XK8 Comfort
Feb 15, 2019 05:03 PM
Stu Baily
Jun 22, 2017 07:26 AM
LondonXK8Boy
Jul 24, 2014 02:12 PM
