Convertible Top Fail
Old Jun 16, 2023 | 11:30 AM
Jim D's Avatar
Default Convertible Top Fail
Cleaning the headliner and taking photos the other day, I stopped the top mid-raise (it had been open), but gravity pulled it open again. So, using the console button, I raised the top to about 3/4 closed and shut the engine off. The top stayed put while I got my task completed.
Now, no pump noise and the top doesn't respond to the button, nor do the quarter windows close.
I have -
1) tried a hard reset by touching the negative and positive battery cables. Held them together about 15 seconds.
2) manually raised the top using the 8mm hex key. Found the top latch mechanism already closed but not through the lock-hoop, so opened the valve on the pump, forcefully lifted the front of the top and got the latch engaged.
3) no joy on pump activating to console button.
Current status - top raised and locked, quarter windows open.
Help!
I'm not very mechanically skilled, even less so with electical issues.
Old Jun 16, 2023 | 11:44 AM
Jon89's Avatar
I would never intentionally stop the top from opening or closing mid-way through the process. That is probably a sure-fire recipe for ensuring the top function unfortunately gets out of its proper sequence. Have you consulted your owners manual regarding what it has to say about re-establishing the top sequencing process?
Old Jun 16, 2023 | 12:14 PM
Dennis07's Avatar
Step 1: check the 40 amp fuse protecting the pump.
Old Jun 16, 2023 | 02:48 PM
Jim D's Avatar
Thanks for the suggestion, but already checked the fuse.
Got the quarter windows (and door windows) to close using the key-in-door process but still no joy with top up / down.
Old Jun 16, 2023 | 02:54 PM
RJ237's Avatar
Use the key to open the windows again, then open the pump valve to relieve pressure with the ignition on. You may have to manually cycle the top a couple of times to get it in the proper sequence.
Old Jun 16, 2023 | 06:35 PM
Johnken's Avatar
Close enough to something that happened to me in 2016.
I copied this from my post back then (i was so happy to figure it our I didn't want to forget). Give it a try:
I shortly found 2 things out:
1) You need something to pry the dummy tab at the latch open. Fingers aren't going to do it.
2) The allen wrench can't move anything until you release the hydralic system pressure at the pump.
I drove home and jumped on my computer for previous threads. It took a bit of digging, but I found the info. These things can get "confused" if you stop midcycle or change direction mid cycle. How did I fix it?
In this case I just had to turn the fluid stopcock counter clockwise all the way (it has a built in stop, you will not pull it out and have your fluid spill). Then I took the allen wrench to the access hole above the rear view mirror. I lifted the roof manually about 2 inches, extended the latch with the allen wrench, droped the roof into it, then locked the latch with the allen wrench. An instant test showed the rear windows now worked. I just tighted the stop **** back up on the pump and everyting works normally. That's all it took to reset things. I hope it helps you if you need it someday.
Hope this nails it for you. John
Old Jun 18, 2023 | 01:41 PM
Jim D's Avatar
Well, lads, I've tried each of the above suggestions more than once, but to no success.
Present condition - top is latched down, windows operable. No noise heard when pressing roof up/down toggle switch.
Any further hints?
Old Jun 18, 2023 | 01:52 PM
Jim D's Avatar
Resolved! Made me very happy.
Did the window reset process, and it fixed the roof problem.
Of course it did! Strangely interconnected system.
Thank you everyone for hints and suggetions.
FLXKR
Dec 14, 2021 07:49 PM
mtmous
Dec 3, 2017 02:01 PM
cat hoarder
Jun 14, 2016 06:05 PM
WillyWheels
Feb 24, 2015 08:36 AM
perrypower1
Aug 21, 2013 06:56 AM
