Convertible Top Non Functioning
Old Sep 1, 2023 | 03:43 PM
Mikeintn68's Avatar
Default Convertible Top Non Functioning
I just bought a 1999 XK8 Convertible. The power roof is closed but will not open. When the switch is pressed the side windows roll down but then nothing else happens.
The 40 amp fuse in the trunk is good and the fluid level is between the lines on the pump.
Any ideas? I am guessing there is a switch somewhere not being made.
Old Sep 1, 2023 | 03:52 PM
motorcarman's Avatar
Jaguar issued several TSBs a few decades ago.
You find and read all of them but here is one in particular.
Old Sep 1, 2023 | 04:06 PM
Mikeintn68's Avatar
I forgot to mention that the speedometer also does not work. I am not sure if the logic uses any info from the spedometer.
Old Sep 1, 2023 | 04:42 PM
Mikeintn68's Avatar
Thank you, in the logic it mentions instrument sending wrong speed. The speedometer does not work so I bet the if I replace the Vehicle speed sensor (assuming thats the problem) the top will work,
Tuohy
Mar 30, 2022 11:40 PM
Hroberts
Oct 25, 2021 09:00 PM
Eric Gramer
Dec 12, 2020 02:13 PM
Magnetvision
Jun 7, 2011 07:37 PM
KeenStacey
Apr 3, 2009 09:37 AM
