My 1999 XK8 is missing the "plug" that covers the hole where I would insert the tool to manually retract the top. The picture, if it's the correct part, is the only one I've found.
I am used to discontinued, tough to find parts being expensive. But if this part is what I imagine it to be, that price is nuts.
Does anyone have an alternative solution? If not, can I get the specs for the plug? I could literally buy dozens, if not hundreds of plastic plugs for that price.
There is a small hole where the 8mm Allen key goes and a larger hole which is where your fingers go to pull the roof into the closed position manually. The larger hand hole was never fitted with a cover by Jaguar whereas the smaller hole has the plug shown by MichaelH above.
I found this on Octoclassic.com. It's cheaper, but still not cheap.
for what it's worth, I ordered the front seat catch lever and surround, for pushing the seat forward to access the rear seat, for both sides of the vehicle. All parts seemed high quality, but had to be painted to match. Fit great and work well.
Octoclassic seems to a developed a business around 3D printing little plastic bits and bobs for a number of older cars where the parts are no longer available.
People, this isn't Rockette Surgery. Go to your local auto parts store, or go on Amazon, and buy a 12 mm plastic plug. I got 20 white plugs for $5.49 on Amazon. I just need to paint it a matching color... or maybe a Union Jack.
I'll be selling them later for $49.95, plus parts and labor. What does the $49.95 cover? Everything except parts and labor.
