Convertible top tension cable
Old Apr 25, 2011 | 12:09 PM
Lifts's Avatar
Default Convertible top tension cable
hi all. When i lowered my top for the first time this year, i noticed the convertible top tension cable was not attached to the frame at drivers side rear. The cable does not appear broken , it has a ball on the end. I did find what looks like a broken cast roll pin. The top goes up and down fine. Can anyone tell me what the tension cable does and how to repair or replace it.
thanks: Lifts
Old Apr 25, 2011 | 12:11 PM
WhiteXKR's Avatar
It might be the interior headliner tension cable. Is one side of your headliner looser than the other?
Old Apr 25, 2011 | 12:20 PM
Lifts's Avatar
thanks white xkr. Never noticed but i will check this aft. And let you know.
lifts
Old Apr 25, 2011 | 04:19 PM
macsr's Avatar
The tension cables keep the top tight against the weatherstriping to reduce wind noise and air infiltration. one broke on my 93 Cadillac Allante and going down the highway at 70mph you couldnt hear the radio. Don't know if the same would be true on the Jag though as mine both appear to be fine.
Old Apr 25, 2011 | 05:17 PM
Gus's Avatar
Gus
I do not have info on this but I am still looking. Do you have a body shop in your area that might give you an idea how and where it connects?
Old Apr 25, 2011 | 07:50 PM
WhiteXKR's Avatar
The top is not secured with cables...seal tension is provided by the big 'claw' that latches the top.
The headliner is, however tensioned with multiple cables. Lightwight rope is used at each end as well as three rows in between verticallly across the top. Jacketed steel cable tensions the headliner at the rear window. From your description, it sounds like the rear window steel cable fastener on one side is broken. It might be easiest to see what is going on by peering behind the fabric on other side that is still intact. The stringing is also described (albeit not that clearly) in JTIS under Body and Paint, Convertible top.
Old Sep 18, 2012 | 01:47 PM
IPG's Avatar
IPG
Default XK8 convertible top liner tension cable under rear window
I think i know why one end of your liner tension cable was loose - because i took mine off to try and find where a water leak was coming from - and now I can't get it back on, on both sides, for the life of me! That cable must have been under some tension! I've tried fastening both ends (which it will do, just) followed by the middle, but the cable will not stretch no matter how much force is applied to allow you to do all the middle nuts up. I've also tried starting in the middle and working out towards each side, again to no avail. My last hope is that the body will shrink as the weather gets colder, allowing me to do up all the nuts that hold it on!
Has anyone else had any experience with this?!!
Old Sep 18, 2012 | 02:26 PM
WhiteXKR's Avatar
My memory is starting to fade on this, but I believe if you stop the roof a few inches before it hits the latch, the tension will be relieved sufficiently on the cables so you can fasten them down.
Old Sep 18, 2012 | 04:08 PM
Gus's Avatar
Gus
When the rams are fully extended the cable is taught resulting in the roof mechanism locking together. Pulling the cable will not stretch it. Once the roof is opened and the rams are unlocked you should have slack to relatch the cable.
Old Sep 19, 2012 | 02:03 PM
IPG's Avatar
IPG
Hi guys,
many thanks for the replies.
I think there may be a bit of confusion around which tension cables I (and the initial poster) refer to - it's the cable (more of a steel rod, really, than a cable) that runs horizontally across at the base of the hood and liner, underneath the rear window. The cable/rod is attached to a silver (aluminium?) strip that I presume clamps the actual hood material to the car body (BIW) through which gold coloured bolts poke and gold coloured nuts are supposed to attach. I don't think they're visible until the carpet lining the convertible top stowage compartment is removed (but it's hard to remember, it's been out that long!).
Old Sep 19, 2012 | 09:51 PM
Gus's Avatar
Gus
Is it possible to get a photo of just a portion of it to be sure we are on the same page?
Old Sep 20, 2012 | 01:01 PM
IPG's Avatar
IPG
Yep, will do - hopefully by this time tomorrow. Cheers.
Old Sep 21, 2012 | 12:32 PM
IPG's Avatar
IPG
Hopefully pic attached..
Attached Thumbnails Convertible top tension cable-hood-lining-tensioners.jpg
Old Sep 27, 2012 | 09:51 PM
Gus's Avatar
Gus
I will look at my car in the morning. I know the cable (Yes the cable that pull the roof joints together) goes from front to back but never had reason to see how it is connected. My assumption is that when the roof is open the linkage of the roof allows the cable to relax allowing the roof to move freely. When the roof is up and closed it is taught holding all the joints taught. Sorry I did not see this earlier.
Old Oct 7, 2012 | 11:31 AM
IPG's Avatar
IPG
Hi Gus,
It's not the cable that runs front to back that's causing me the arm-ache - it's the (much thicker and stronger) cable that runs side to side across the back of the car underneath the rear window. It just will not stretch! I have no idea how they got it on, it's that far out. I'm considering taking it out, and re-positioning the 'kink' in it that provides the tension.
IPG
Old Oct 8, 2012 | 08:22 PM
Gus's Avatar
Gus
I looked and the cable that I think you are talking about connects to the cable that goes along the roof to the front. I will look again and identify the cable section you are talking about.
Old Oct 8, 2012 | 08:50 PM
WhiteXKR's Avatar
OK, I believe that is the curved metal rod that fastens the bottom of the headliner to the frame. It is meant to be installed as one of the first steps when putting in a new headliner, so it is difficult to do with the headliner in place.
I still think that if you just begin to lower the top, and stop it 3-6 inches from the header you will create enough slack to fasten it back down and still have enough room to get yourself under it. You may need to prop the top open with something soft (like a pile of rags) so it stays in this slightly open position on its own, because it likely will have a tendency to want to drop down to the header.
FrickenJag
Jun 16, 2025 02:15 PM
bamforp
Aug 14, 2024 05:36 PM
RoyLittle0
May 25, 2023 02:38 AM
Rlover
Mar 30, 2016 10:04 PM
Bowman
Sep 15, 2015 06:54 AM
