convertible window issue
Old Apr 3, 2015 | 09:48 AM
drpsmith's Avatar
Default convertible window issue
both sides
windows up when opening door window opens to clear top
close the doors window does not return up
open door again window drops down more each time you open the doors
any help out there with this one???
2001 xkr
Old Apr 3, 2015 | 10:16 AM
I've moved your post from the General Tech section to the XK8/R section where you will get a better response.
Have you tried resetting the window limit switches? Hold the switch in the down position and as the window reaches the bottom limit, hold for about 5 seconds more listening for a faint click. Then do the same in the up position - again listen for a faint click
Old Apr 3, 2015 | 10:24 AM
test point's Avatar
The window motors draw a lot of current as witnessed by the 30a fuse for each of them. That much load on a weak battery will draw the voltage down below what is needed to maintain window position memory.
A quick, free charging system check at your local auto parts store will determine if you battery is getting weak or you just haven't driven the car enough.
Old Apr 3, 2015 | 10:38 AM
Gus's Avatar
Gus
Remember to be in the car with the door closed when you do the reset.
Old Apr 3, 2015 | 11:05 AM
brgjag's Avatar
ditto on batt check.
Old Apr 4, 2015 | 01:58 PM
drpsmith's Avatar
Thumbs up Window issue
Thanks all for the quick response. She'd been wintered in the garage but started every day, Definitely will get the battery checked. Not sure how old. Reset per suggestions. Again thanks all you guys are a great bunch. Paul Smith Amherstburg Ontario
Old Apr 5, 2015 | 10:40 AM
bar20's Avatar
I had the same problem on my XK8 that I picked up yesterday. The side windows would drop down and not come back up automatically. I tried your 5 second fix and it worked like a charm. I did both sides and now they drop and come back up. Thank you very much. Now if I can get the key fob I ordered from ebay to program according to the programming procedure in another thread, I'll be a happy camper
Steve
1999 XK8 convertible-- Alpine Green
1948 MG TC-- MG Red
Old Apr 9, 2015 | 02:18 PM
Jacob67's Avatar
So this can happen if the battery goes empty?
Old Apr 9, 2015 | 02:49 PM
batroute's Avatar
Yes - it's often the first sign of a weak battery. The windows also need to be reset upon reconnection if the battery has been removed from the car.
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Raul Lara
Sep 14, 2015 07:31 PM
obwoodie
Sep 3, 2015 07:45 PM
