Coolant hose clamp leaking. its a weird clamp
Old Feb 17, 2021 | 02:00 PM
Rob Benjamin's Avatar
Default Coolant hose clamp leaking. its a weird clamp
Hello! I have a 2000 xkr that has been leaking coolant. I attached a pressure tester to it and found one place its leaking, I hope this is the only spot. The picture shows the connector and it is not adjustable. Im wondering what kind of hose clamp this is and if i can remove it and replace it with something that I can tighten. Why would these kind of clamps be used? Is this the type of thing that once they fail you have to replace them??? Thanks!
Its the hose clamp in the center of the pic.
Old Feb 17, 2021 | 02:06 PM
bladerunner919's Avatar
Isn't that supposed to be one continuous hose?
Old Feb 17, 2021 | 02:25 PM
Maybe? These hoses are made by URO. I did a quick search and they are aftermarket.
Old Feb 17, 2021 | 02:35 PM
max224's Avatar
If these are the same ones that I have on my 2000 XK8 they have a weird connection between the two ends which is not adjustable. They are apparently designed that way to provide even circumference pressure and to prevent over tightening which could crack a plastic hose fitting. I've been able to take them on and off using a pair of needle-nose pliers. If I'm wrong (a reasonable possibility), I'm sure someone will chime in and give you the correct information.
Old Feb 17, 2021 | 02:42 PM
Are they not Worm Drive clamps with the tightening screw out of sight underneath?
Old Feb 17, 2021 | 02:47 PM
Jon89's Avatar
Avoid URO hoses whenever possible. Over the years I have unfortunately installed several of them (before I knew any better) and they ALWAYS suffer from a leak somewhere, sometimes within just months of being installed...
Old Feb 17, 2021 | 03:03 PM
I wish they had an adjustment of some kind. These are just metal bands.
Old Feb 17, 2021 | 06:01 PM
giandanielxk8's Avatar
Those "clamps" are neither adjustable, nor removable. It's meant to be a single continuous hose with branches. That lower radiator hose, especially if made by ÜRO, I would rather replace the entire thing instead of mending it. Knowing ÜRO, it will leak from another spot on the hose after you fix it.
Old Feb 20, 2021 | 01:26 PM
I wouldn't say I fixed it but it isn't leaking from this spot anymore. I think i bought myself a little time I hope...
Old Feb 20, 2021 | 02:25 PM
fmertz's Avatar
Looks like a serious cut by the clamp in that hose. Remember, the hose has a "fabric" base for strength, coated with rubber. If this repair somehow fails, this will leave you stranded...
Best of luck, keep us posted.
Old Feb 20, 2021 | 04:03 PM
RJ237's Avatar
Looking back to the pic in post #1 I'd say that cut occurred when cutting the original clamp off. Can you fit another clamp over the cut?
Old Feb 20, 2021 | 04:19 PM
Jon89's Avatar
Never trust a URO hose, especially a damaged one. I would replace that hose as soon as possible....
marcela
May 19, 2020 02:07 PM
OUScooby
Nov 26, 2018 05:59 PM
Spikepaga
Jan 28, 2015 10:00 PM
kvmentor
Feb 19, 2011 08:24 AM
