coolant level float
Old Oct 16, 2013 | 02:23 PM
jmillerga's Avatar
Default coolant level float
My boat won't float nomore. Somewhere I saw something on cutting a piece of foam to put under the float to solve this problem without replacing the whole tank. It appears as age has stopped me from finding it again. Any ideas or where to look would be appreciated.
2001 XK8
Old Oct 16, 2013 | 02:34 PM
Jon89's Avatar
Try searching using "coolant reservoir float repair" as your key phrase....
Old Oct 16, 2013 | 05:44 PM
You don't need to replace the Expansion Tank. The Fluid level Sensor is available separately (item 4):
Part Number LNA5740AB. It clips into the bottom of the tank.
Old Oct 16, 2013 | 05:52 PM
Brutal's Avatar
Unless the float sinks or sticks to the bottom. If the level goes down the float many times sticks to the bottom and i use a pick to lift it and make it float again. The sensor wont fix this issue. And i would prefer a proper fix since theyre not that expensive. Last thing you need is a non working level sensor to warn you you're low or out of coolant(you dont know) and blow a head gasket or engine
Old Oct 16, 2013 | 06:20 PM
WhiteXKR's Avatar
I definitely agree with Brutal.
Replace the tank if it has a sticky float.
The low coolant warning may be your only savior if you were to have a major coolant loss, such as a burst hose. In these cars if the coolant level is too low you will never see an overheating warning because the fluid would be below the temperature sensor. Take your pick: around $100-$200 for a tank now or around $5000-10,000 for a replacement engine later.
Old Oct 16, 2013 | 08:41 PM
pmstsc's Avatar
Mine just started sticking. thanks for the info.
Old Oct 17, 2013 | 08:51 AM
MRomanik's Avatar
Veteran: Air Force
Search for "Low coolant message- Resolved" in this forum.
I put in a foam ring a year ago and still holding up. I do check my coolant level weekly and monitor the temp with an UltraGauge.
Old Oct 17, 2013 | 09:25 AM
Jon89's Avatar
I also check the coolant level at least weekly. You really cannot check it often enough with these cars....
Old Oct 26, 2013 | 06:58 AM
espy1949's Avatar
hi guys, i had the same issue on my 99. i got a new tank which comes with a new sensor in place from the parts geek for 150.00 after i replaced it i decided to disect the old tank just to see what was going on. what i found was a real sludgy float that most likely could have been cleaned and good as new. what i would do first is remove the tank (simple) and use dawn dish soap or any type of cleaner my guess is that it would free up which you can check by inverting the tank and jiggling it up and down you'll probably hear it moving. once that is done reassemble, fill with coolant and your probably all set. (i wished i had tried it before spending the dough) since it removes fairly easy i'd try that before i replaced it. also a good ideato flush your radiator and renew the coolant good luck
Old Oct 26, 2013 | 09:56 AM
MRomanik's Avatar
Veteran: Air Force
espy1949, when I was having this problem I removed the tank and cleaned it with radiator flush. The float moved freely but that didn't solve the problem. I believe the float just got too heavy over time.
Old Oct 26, 2013 | 10:15 AM
Jon89's Avatar
Agreed. It's much safer to simply replace these plastic tanks and floats. Once they degrade, they can become engine-killers in a heartbeat....
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
vwbusbits
Oct 13, 2015 03:43 AM
BSM
Sep 25, 2015 05:00 PM
