Coolant shot out from underneath the hood
Old Aug 23, 2021 | 02:22 PM
jjohnson's Avatar
Unhappy Coolant shot out from underneath the hood
So, I have a 1997 Jaguar XK8. I've had it for three years now, but its been in storage because I didn't want to take it down to Texas where I was stationed in the Army. Anyway my point is I was driving it on the highway and stupidly I pushed it up to around 95 mph and coolant started shooting from the sides of the hood all over the front and sides of the car. I was close to home so I just parked it in the garage and it's been sitting for about a month. I'm not sure what the issue is, I know almost nothing technical about cars. I've read up on other posts regarding coolant leaks but I haven't come across any posts with any similar issues. I'm just hoping to get a little insight on what I can do about this. I've gotten an oil change once per year since I've had it, no more considering how little I was driving it, but I haven't taken it anywhere to have it properly serviced (I think this is probably why this happened). This is the first nice car I've ever owned, and I know I've been irresponsible and lazy, I just hope this doesn't end up being crazy expensive. I'm assuming I'm gonna get **** from car people, but I really need help.
Old Aug 23, 2021 | 04:32 PM
Welcome to the forum - as this is your first post - take a moment to stop by the new member section and post an intro - in return, you'll receive a warm welcome and useful tips to navigate the forum. https://www.jaguarforums.com/forum/n...-intro-must-5/
As for the coolant leak - recommend a visual to see if there are any ruptured hoses. If nothing visible, Advance Auto or AutoZone loan pressure test kits - get one, fill back up with coolant and pressure test the system - it will tell you where the leak is, but just the simple fact it is a 1997 and driven very little over the past 3 years - hoses and seals tend to dry rot - so let us know what the pressure test yields.
Go to https://www.sngbarratt.com/English/#...anada~2FUSA/45 for parts break down
Old Aug 23, 2021 | 10:42 PM
Johnken's Avatar
+1 with sklimii,
Friend we could list the numerous places that have tended to leak, but it'd be a lot more productive for you to do that visual.
I'm sure you know you'll need to fill up the coolant level for the tests. Yes you can use plain water as long as you know you'll have to ensure the hot / cold protection levels will need to be monitored after you fix the leak and are putting her back on the road.
Lots of leaks won't show until she's hot and up to temperature.
Looking forward to hearing your findings.
John
Old Aug 24, 2021 | 01:34 AM
Pistnbroke's Avatar
Hope you washed the bodywork well as the antifreeze is corrosive to paint.
Old Aug 24, 2021 | 09:32 AM
TropicCat's Avatar
Note: If you do try to pressure test the system yourself you'll need a pressure tester adapter. Your local auto parts store isn't likely to have one that the rent or loan that will fit your car. The parts store can order one that you can buy, you can find one on-line and buy it, or ... you can buy the one I have listed in the classifieds.
https://www.jaguarforums.com/forum/market/250165
Old Aug 24, 2021 | 10:40 AM
Jon89's Avatar
The pressure-test kit I borrowed from our local Advance Auto Parts store came with the appropriate adapter in the case. It probably contained six or eight different sizes and shapes of adapters. The one that looked most like an ice cream cone was the one that worked for me. That was back in October 2014....
Old Aug 24, 2021 | 03:18 PM
Pistnbroke's Avatar
Why dont you just top it up and run it up to temperature and see where it pisses out ...EPLS
Old Aug 26, 2021 | 10:45 AM
jacktoth's Avatar
i own a 1997 xk8 with 61K and have replaced every hose and "plastic" cooling system part over the past 6 years. It is a complcated system with numerous hoses (at least 10, yes 10) in places very hard to reach. Given your skill level I would find a good independant garage that has worked on these cars. Be prepared for $$ shock. For me its a hobby car to indulge my mechanical fancies, not a dependable mode of transportation.
Old Sep 8, 2021 | 07:44 AM
jjohnson's Avatar
Hey everyone thanks for the advice. I took a look inside and it looks pretty obvious where the leak came from. I couldnt get the hose clamp back around the hose and the part its supposed to connect to, but I'm sure I can get it on if i use some hand tools. Do i still need to pressure test once I get it back on?? Today I'm gonna try what Pistnbroke said and just top off the coolant and see if it still leaks.
Old Sep 8, 2021 | 07:48 AM
jjohnson's Avatar
thanks for the info, luckily I washed and waxed the car the morning that this happened. I didn't know it was corrosive so I haven't clean it since, but there was no damage and the coolant came off easily when I wiped it with a rag. I'll be washing and waxing it today after work.
Old Sep 8, 2021 | 07:49 AM
jjohnson's Avatar
Defaultthanks for the info, luckily I washed and waxed the car the morning that this happened. I didn't know it was corrosive so I haven't clean it since, but there was no damage and the coolant came off easily when I wiped it with a rag. I'll be washing and waxing it today after work.
Old Sep 8, 2021 | 07:51 AM
jjohnson's Avatar
Thanks for the response, I posted some pictures of the hose that came loose, anything like that ever happen to you?
Old Sep 8, 2021 | 11:00 AM
RJ237's Avatar
If the hose popped off a plastic fitting, don't expect it to stay in place. The plastic degrades over the years, so you should replace the thermostat tower, preferably with aluminum, and the outlet pipe.
Old Sep 8, 2021 | 12:45 PM
fmertz's Avatar
I'd say take a hard look at the inside of that hose as well as the thermostat tower. That white residue suggests one of those cheap leak stopper products (or even mixed incompatible coolant). You might want to take advantage of this repair to perform a more comprehensive cleaning of the entire cooling system, even at the risk of re-discovering an existing leak.
Old Sep 8, 2021 | 12:51 PM
Jon89's Avatar
^^ I concur. That white residue could indeed indicate a problem. You do not want a mixed bag of coolant products circulating through your cooling system. If it gels up, it could wind up killing your engine at some point....
Old Nov 13, 2021 | 04:52 PM
jimejag's Avatar
Default XKR List of Cooling Hoses to Replace?
I have a small leak that I have been putting up with for awhile. I did the pressure test several months ago, but was unable to locate the source. Orange cooling fluid at first was showing around the crank pulley and more recently it is dripping out under the bell housing area.
With cold weather coming on, I'm thinking of putting it in the garage and pulling off the supercharger and top parts to replace whatever hoses lie underneath and behind.
Does anyone have a list of part numbers and/or photos/videos/best sources to get the replacement hoses?
As a preventative measure I want to do all the hard ones to get, the top easy to change ones I can do if and when they fail.
Old Jun 3, 2022 | 08:33 AM
piper 888's Avatar
Does anyone have a list of all the cooling hoses so I can pre order them and not have to wait after I remove the old ones and have to wait for them to come in while the car is inoperable/ I have a 1998 XK8. Thanks
Old Jun 3, 2022 | 10:14 AM
Johnken's Avatar
Piper goto SNG Barrett. Download parts catalog. This is 1 of 3 pages with cooling hoses.
John
Attached Thumbnails Coolant shot out from underneath the hood-screenshot_20220603-111157_adobe-acrobat.jpg
Old Jun 3, 2022 | 10:50 AM
michaelh's Avatar
Here you go:
https://www.jaguarforums.com/forum/x...9/#post2466950
Old Jun 4, 2022 | 06:42 AM
jacktoth's Avatar
Default And Don't ignore.......
Ditto on the SNG Barrett Catalogue as guide; its what I used to replace all of my '97 xk8 hoses, including the real nasty one under the intake manifold and those connected to the heater valve, etc.
eksjaysix
XJ40 ( XJ81 )
Oct 6, 2021 10:31 PM
saturdays
May 26, 2018 08:05 PM
Anthony8858
May 19, 2017 06:26 AM
Silver_Surfer_XF
May 14, 2015 05:09 PM
muellesx
19
May 15, 2014 03:30 PM
