coolant tank
Old May 30, 2014 | 05:28 PM
Originally Posted by jsulliva
........... I still don't see how it all works and I have never seen a tool like that. ...........
The CLOSED clip is on the right; the OPEN clip is on the left:
To OPEN with a pair of pliers, squeeze the two shoulders arrowed in red together.
To CLOSE, squeeze the two shoulders arrowed in blue together.
It doesn't require much force to open or close these clamps.
Old Jun 2, 2014 | 01:16 PM
jsulliva's Avatar
Thanks for the photo and explanation. I now understand.
John
Old Jun 2, 2014 | 02:13 PM
Fulton's Avatar
Originally Posted by tony bosco
hi forum , today i did my coolant tank and it was pretty much of a breeze. took my time ( 1/2 hr. to 45 min.) and my light is finally out. just hope it stays that way............... thanks to everybody for their advice........ tony
Great, I love happy endings
My coolant level light has been out for 12 months now
Old May 5, 2024 | 09:39 AM
Ktmscott's Avatar
Default 2001 xk8 expansion tank leaking.
any aluminum alternatives to the plastic expansion tanks offered.
Old May 9, 2024 | 07:24 AM
Ron62's Avatar
Be aware of the following. I had the light on for the coolant level. Changed the sensor, no success. Changed the tank, no success. Because the level was not dropping, i kept on driving the car, until it started to smoke like a lunatic. Went to my Jag specialist which told met the head gaskets failed. Had both replaced. Than the next thing came up. The catalysts failed because cooling fluid came into the exhaust pipes and ruined the catalyst stone in both the catalysts. You can imagine what that costed in the end.
Old May 9, 2024 | 03:17 PM
robak's Avatar
got the same problem with the new tank. shows low level but level is ok.
how come you lost fluid but it didnt drop in the tank???
Old May 9, 2024 | 06:02 PM
zray's Avatar
his posts sound like a lot of damage was caused by very little fluid loss ?
on one hand he says the light came on, another other hand he says the level wasn’t dropping.
But the light is activated by the level dropping.
I’m confused as to what really happened ??
Old May 10, 2024 | 09:28 AM
  #28
Ron62's Avatar
I'm still confused. No level drop but still the coolant went out with oil thru the exhaust. Probably because the top up of coolant was not done without a vacuum device. Better spent little money on a vacuum device for topping up coolant to fill the tank because otherwise you loose coolant without knowing. Opened up my eyes and took the advise from my specialist. Now i spent about 25 pound for the vacuum device but know i'm safe. It costs me a lot of money for the head gaskets and the catalysts. Lucky for me the heads where salvaged. If they fail as well during the head gasket issue, i had to find proper heads as well because of valve damage. Its far more complex with these engines than a simple A series Austin/Morris/Rover unit.
major90
Feb 9, 2014 02:56 PM
EZDriver
Jan 2, 2014 03:09 PM
Alwann
Oct 3, 2010 12:13 AM
hafferf
Mar 23, 2010 08:24 PM
laurielalone
Mar 2, 2010 08:05 PM
