Correct Ground Clearance for Convertible?
Old Oct 29, 2019 | 05:43 PM
Jpattr7's Avatar
Default Correct Ground Clearance for Convertible?
This post is designed to draw opinions on acceptable ride height:
Measuring from ground to the top of the wheel wells I get 27 inches at the front and 28 1/4 inches at the rear
Measuring from ground to the support bar for the radiator I get 5 1/4 inches clearance
The original tire specs called for 235/55/ZR17
Mine are 245/50/ZR17
A search from the web indicated that the installed tires are slightly higher in profile - giving a 2% error in the speedometer reading (everything being accurate there)
Front tire pressure is 28 pounds / rear tires are at 30 pounds
I had to adjust the headlight assemblies to their maximum in order to get adequate low beam lighting of the roadway.
The owner's documentation claims correct clearance is 6.4 inches.
So I can conclude that the front assemblies are low - leading to the rubber assemblies at the top of the struts have shrunk (observation leans to them being OK ) or that the springs have become tired
The car has low enough mileage (43000) to suggest that the suspension has not been abused.
When driving, the car corners flat, even when put under some stress. Driving on flat highway is extremely pleasant. If the pavement is cracked or not level any imperfection is noted somewhat harshly. The shocks are not leaking and have not gone "soft" i.e. no wheel bounce. We also own a 2012 Ford F150 (two wheel drive) and a 2010 Hyundai Santa Fe - the ride with about the same harshness.
What started this situation was a near miss with a large watermelon, left in the center of the highway. I came upon it around a curve, but courtesy of good engineering, avoided the thing. This set me back down the what if ?
path of damaged front grill / radiator / air bag deployment, etc. We live in a rural setting and have seen lots of wooden and metal road hazards, but killer fruit is a new twist.
I have consulted youtube, discovering that replacement of the top strut assemblies is far more annoying than replacing entire strut assemblies.
So here are the questions - 1. Should the car have a slight rake, with the rear somewhat higher? 2. What is an acceptable ride height - given that working on the suspension will probably lead to replacement
of bushings? 3. Is the harsh ride typical?
I'd appreciate any comment.
Old Oct 29, 2019 | 06:16 PM
michaelh's Avatar
Here are the ride heights and how to measure them from the vehicle specs:
I guess anything over 1" low and the suspension is tired. Rear is slightly higher so the car does look to rake somewhat. The ride should definitely not be harsh:- it is, after all, a Jaguar
Old Oct 31, 2019 | 05:49 AM
CorStevens's Avatar
these cars tend to "feel" washboard surfaces more than others. sometimes, especially when moving slowly, it is like one can read the road height variations like braille.
Old Oct 31, 2019 | 09:21 AM
Johnken's Avatar
I know what you mean Cor. Found out long ago that it'll be a lot more comfortable driving over speed humps at speed instead of slowing down. Not sure if that's a local term. Speed jump = those artificial bumps they put in parking lots to regulate speed.
John
Old Oct 31, 2019 | 03:32 PM
michaelh's Avatar
AKA 'sleeping policeman'. Those abominations get everywhere
Confess I hadn't noticed that sort of harshness.
Old Oct 31, 2019 | 06:30 PM
CorStevens's Avatar
John
it cannot be good for the car to hit speed humps at speed. i was referring to road patches and other transitions and the generally crummy way that road paving has evolved. the authorities cannot seem to get a new paving job smooth anymore. perhaps all of the old timers have retired.
Old Jul 9, 2025 | 02:38 AM
mountain's Avatar
Michaelh
Re 1996 XK8.
Thanks for th reply. I measure 385 mm so as I suspected, the springs are 'tired' and the tyres occasionally touch on the liner.
Replacement springs seem unavailable in Aust. so I will investigate having the old ones reset.
Who might have a specification for heat treatment and does anybody know the free length of the front springs.
208000 km. Apart from the springs it runs like a charm.
Old Jul 9, 2025 | 07:53 AM
michaelh's Avatar
Originally Posted by mountain
Michaelh
Re 1996 XK8.
That measurement seems to be in-spec?
Perhaps it's the shocks that are tired at that mileage. Also, check the condition of the lower shock bushings and, particularly, the upper shock mounts.
There are two forum members (cjd777 and baxtor) who have collaborated to produce replacements for the uppers, and baxtor is also located in Oz.
I'd drop him a private message as I'm sure he will be able to offer you some good help and advice.
Beautiful car btw - and my favourite colour.
stham
Jul 16, 2018 07:07 PM
Supersprint
Apr 29, 2018 10:40 PM
Pantera928
Jun 6, 2016 07:05 PM
mskelly007
Apr 7, 2015 01:27 AM
flyrr100
Jul 2, 2013 01:00 PM
