Correct torque figure for front upper wishbone pivot bolt
Old Jan 26, 2014 | 01:56 PM
MCW739's Avatar
Default Correct torque figure for front upper wishbone pivot bolt
The JTIS gives two figures, 60-80Nm and 98-132Nm - does anyone know which is correct?
Reason I ask is last summer I replaced the upper bushes to one side and tightened the bolt to 120Mn, ie mid range higher value. I am now in the process of a full bush and joint replacement but when I came to remove the pivot bolt it was stuck fast and only by drifting it out was I able to remove it. The cause was the steel end washers of the new bushes has tightened onto the shaft. My supplier has not had this problem and I don't suspect poor quality product for one moment. He suggested what I thought that the pivot had been over tightened causing the washers to spread - thoughts?
Old Jan 26, 2014 | 04:24 PM
bsprowls's Avatar
I have an ALLDATAdiy.com subscription for my 97 and it lists the following:
Nut - wishbone upper fulcrum 98-132 nm
At least you have an opinion from a source other than JTIS. Hope this helps.
Old Jan 27, 2014 | 04:49 AM
MCW739's Avatar
Originally Posted by bsprowls
I have an ALLDATA.diy.com subscription for my 97 and it lists the following:
Thanks Brad,
I'll have to check my torque wrench next.
dsnyder586
Dec 29, 2024 07:39 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
cissdm
May 3, 2016 06:02 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
