Corrosion, anyone? (Engine Fault, 3rd and Final Round)
Old May 18, 2023 | 06:42 PM
jim_63219's Avatar
Default Corrosion, anyone? (Engine Fault, 3rd and Final Round)
A quick recap: Chasing an Engine Fault led to a failing P/N switch, confirmed via back-probing the G wire off of the rotary switch. So I opened it up, and well well well... lookie here; this is after I already cleaned the back plate. It was absolutely caked in white:
I am spraying the snot out of it with WD-40 Electronic Contact Cleaner. After spraying, here are the backing switches, a close-up:
I hesitate to attempt mechanically cleaning these, as I would rather not risk a reduction their spring action. I'm considering different methods, perhaps a baking soda & water solution, or perhaps even a bit of Diet Coke or something; I am fairly certain the white-cake corrosion plus the copper / green corrosion has led to inconsistent contact. What is a mystery still, is why this would be the case only after a significant driving period, but clearly this corrosion is an issue.
What do you all think for the best method to clean / refurbish this unit?
Old May 18, 2023 | 06:52 PM
cjd777's Avatar
I would start with a tooth brush and WD40.
Might have to go to baking powder and tooth brush, washed out with WD40.
Old May 19, 2023 | 01:21 AM
Pistnbroke's Avatar
I have known ignition switches go on fire after being squired with WD40 ( Spark) and its 10 % oil so stick with the contact cleaner and dry in an oven at 40 c before you re fit it.
I think you are going to end up changing all the switches.
If N/A in US I can look in UK and post. or whole unit from jag spares
Old May 19, 2023 | 05:39 AM
michaelh's Avatar
Ugh. Looks like it's been waterlogged at some point.
Agree with pb that those switches would be best changed:- I'm surprised that it's only the P/N one that's playing up. There appears to be a part# embossed on them so you have some hope of finding replacements.
Old May 19, 2023 | 06:09 AM
Originally Posted by michaelh
..... Agree with pb that those switches would be best changed .....
+1
You may get it WORKING but getting it RELIABLE could be a step too far.
Old May 19, 2023 | 08:49 AM
dibbit's Avatar
Those transmissions were used on so many different makes and models of cars, it must be possible to find one in a junk yard near you, even if you had to re-wire the connector or transplant the micro-switches its going to be a better option than trying to revive that basket case.
Old May 19, 2023 | 09:35 AM
xalty's Avatar
not how it works. jaguar l1-l4 chart is totally different
tons of ones from a jag on ebay
Old May 19, 2023 | 10:02 AM
Pistnbroke's Avatar
if you need parts shipped from the UK let me know
Old May 19, 2023 | 10:05 AM
dibbit's Avatar
You mean the microswitches are different?
Old May 19, 2023 | 12:56 PM
barnter's Avatar
You could try soaking it in white vinegar for a few hours, then washing it off with water.
Old May 20, 2023 | 06:59 PM
jim_63219's Avatar
If you have one lying around, sure, but Don’t want you to go to too much trouble.
I did fit the part today, but no good. Pulled it and soaking in vinegar for a day, we’ll see.
Think those switches will be tough to pull and replace without cracking all that ancient plastic
Old May 21, 2023 | 01:39 AM
Pistnbroke's Avatar
did find this one today on UK ebay but at £168
ROTARY SWITCH / AUTOMATIC GEARBOX SELECTOR - Jaguar XJ8 XK8 1996-2002 | eBay
Seems the one for the xj8 is the same ..I found one at £128
Auto reserve wont ship to America but they will ship to me and I could DHL it to you. Air mail is very slow.
UPDATE
Found loads on US ebay at a bout $200 some with free shipping from the UK
Old May 21, 2023 | 09:27 AM
jim_63219's Avatar
Yeah, I was considering used via Ebay as last resort if these are known to fail. But I did manage to find one that has a return guarantee. So I'll go for that. Thanks for your offer anyway.
jim_63219
May 13, 2023 10:23 PM
Stephjac
May 3, 2021 07:58 PM
Doug
Dec 17, 2020 09:00 AM
Tony S
Nov 2, 2020 05:52 AM
XJRJeff
May 11, 2018 07:32 AM
