Crank no start
Old Dec 7, 2024 | 10:52 AM
David Wichmann's Avatar
Default Crank no start
My cross pipe was leaking coolant, so I replaced the cross pipe and also the water pump in my 2005XK84.2
Now I have a crank no start. I will attach some codes that came up mainly won’t communicate.
these are the error codes that came up for my 2005 XK84.2
Old Dec 7, 2024 | 12:08 PM
motorcarman's Avatar
Can you access the EDR 37 frames of Data? (P1582 Engine Data Recorder)
Sometimes the info actually comes in handy.
Most of the time I just delete it if there are no problems with the car.
Old Dec 7, 2024 | 01:17 PM
Default EDR
How do i access EDR
Old Dec 7, 2024 | 06:56 PM
WDS and IDS have a function to read and clear the 37 frames of info in both A & B channels of saved data as well as reading START TIME RELIABILITY.
The application is in the SETUP and CONFIGURATION tab at the top of the screen.
I have no idea if other diagnostic devises are capable?
If P1582 is logged, the data is saved.
The ONLY way I know to clear P1582 is to access the data, then clear it.
P1582 is NOT a fault, just an indicator that data is stored.
I tried to find a document describing the feature but I do remember instruction on the procedure when it was introduced on the X100/X308 cars during a training session in the late 1990s.
I probably have a paper student guide with info but I have so many 3 ring binders of training classes, I would need to open the plastic tubs and 'reminisce'.
Old Dec 9, 2024 | 08:57 AM
JagV8's Avatar
Here is some info
File Type: pdf
Old Dec 9, 2024 | 10:45 AM
I do remember Steve Petry sending me this .pdf years ago.
Good find JagV8!!!!!!!!!!!
Old Dec 9, 2024 | 03:20 PM
Default Thank you
Thank you
I will check it out later this evening
I appreciate the response
sunchip
Aug 28, 2023 09:21 PM
PitchJaguar
May 15, 2023 03:34 AM
Tony_Likes_Going_Fast_XJ8
Dec 3, 2022 04:12 PM
ArabianKnight
May 7, 2020 09:34 PM
Kenika65
Jul 29, 2018 11:22 AM
