crank position sensor
Old Dec 1, 2008 | 10:38 AM
Idrivejags's Avatar
Default crank position sensor
I hope all had a great thanksgiving.
I have been researching my problem for a lil while. I assume it to be the crankshaft position sensor. My question is WHERE IS IT? and is it easy to replace myself.
Old Dec 1, 2008 | 02:36 PM
test point's Avatar
Default RE: crank position sensor
It is located on the flywheel housing and would appear to be easily accessable. What led you to the conclusion that you had a Crankshaft Position Sensor problem? Haven't heard of any problems with this item.
Old Dec 1, 2008 | 03:54 PM
Idrivejags's Avatar
1999 XJR I have been reading on this board and wanted to try it before I replaced a fuel pump. When I attempt to start car it turns over and starts but dies(stalls) immediately. I have replaced fuel pump relays but no change. would you suggest something else? I am also no mechanic but mechanically inclined.
Old Dec 1, 2008 | 04:16 PM
test point's Avatar
Do you have a check engine light? If so, you need to have the OBDII codes read. If not, it wouldn't hurt to read them anyway. Several of the big national auto parts outlets will read them for you free. A sensor failure will surely set a code. The codes will usually point to the problem, or at least offer several suggestions as to the solution. There a large number of issues that could cause your problem.
Old Dec 1, 2008 | 04:23 PM
Idrivejags's Avatar
I am not getting a check engine light. would i get a code with no check engine light? BTW my car was running fine until the was a gas shortage and I had to put lower grade in the car with octane booster.
Old Dec 1, 2008 | 05:39 PM
H20boy's Avatar
Fuel filter perhaps clogged beyond acceptable limits...
Old Dec 1, 2008 | 06:18 PM
test point's Avatar
Like Matt, I would suspect fuelbefore than a crank position sensor (CPS). The CPS controls timing input to the ECM but is far down my list of things to replace unless you know something we don't. Get a code readout. Can't hurt, and yes, you can get codes without a check engine light. These cars are so electrically complex that using the internal diagnostics is the only way to chase issues.
I guess if the car will not run, driving to a parts store is a little more of an issue. I have never seen a fuel filter completely stop a car from running, only affecting performance.
Old Dec 2, 2008 | 11:35 AM
Spurlee's Avatar
In my experience with other cars a defective Crank Position Sensor would definately send a code and trip the check engine light - it's a pretty basic and fundamental part and drives alot of other systems.
If there is a fuel pressure regulator on these engines I'd check that. (I couldn't find one listed in my parts catalog, but I'm new to Jaguarso I don't really know...)It's an easy fix when rough idling, backfiring and slow to restart issues come up...
Old Jul 31, 2012 | 08:50 AM
mudjag's Avatar
i have a crankshaft sensor code on my 2000 xk8. I would like a diagram of where it is or a video for the the XK8 not and XJ8. thanks
mrplow58
Jan 21, 2024 05:53 AM
RoyLittle0
May 25, 2023 02:38 AM
joesoap
Sep 10, 2015 01:09 AM
1964Daimler
Sep 9, 2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
