Dashboard rattle
Old Oct 13, 2023 | 10:35 AM
Rodkel's Avatar
Default Dashboard rattle
1999 xk8 rattle from dashboard area, seems to be on driver's side. Any suggestions or information on this?
Old Oct 13, 2023 | 11:52 AM
Jon89's Avatar
Are your front upper shock mounts the original ones? If so, they are disintegrating. When the upper shock mounts begin to fail, it often causes rattles that sound as if they are coming from the dashboard area....
Old Oct 13, 2023 | 12:34 PM
motorcarman's Avatar
TSBs from when I worked at the dealer.
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 13, 2023 | 02:03 PM
drmike's Avatar
I traced one rattle to the vents by the windscreen and used some foam insulation wedged in there to stop it. There's a thread somewhere but the squeaks and rattles PDF from motocarman was very helpful.
Another rattle came from behind the small speaker grille by the A post.
I have a most irritating rattle if I have the driver's seat too low. It's something to do with the seat belt mounting but I can't work out what.
Old Oct 13, 2023 | 04:48 PM
There was a TSB for a creak in the seat riser.
Check your VIN
Old Oct 14, 2023 | 03:38 AM
Redjags's Avatar
I spent hours searching for a rattle behind the dash. As others have pointed out, it was worn shock mounts transmitting noise to the firewall and I would have bet money that it was behind the dash. On convertibles the extra bracing makes the transmission of the noise even more startling. A simple check is to look at your shock mounts and determine whether they are central or have moved off centre and are causing the rattle.This is what they should look like.
Old Oct 14, 2023 | 10:23 AM
Flash-1973's Avatar
Default Dashboard Rattle
Good Morning from S. Florida, I had a driver side squeak/rattle 01 XK8 and until diving in a covered parking garage with windows down was I able to determine it was the hood/bonnet latch that needed lubricating. That’s after cracking defrost vent and removing lower dash. Good luck, hope it’s that easy of a fix.
Iticip
Oct 30, 2025 04:28 PM
JDog
Dec 8, 2022 03:57 PM
WaterDragon
Jul 2, 2021 06:01 PM
Supercharged81
Aug 19, 2019 06:10 AM
ukdude
Mar 7, 2015 07:38 AM
