Dashboard squeak
Old Jun 19, 2025 | 08:38 PM
Phillipw's Avatar
Smile Dashboard squeak
I have a beautiful XK8 convertible.
I had this squeak coming from the dashboard. It would come and go for no reason. It was hard to tell exactly where it was coming from. The steps I took were:
1. Removed and checked the vents along the top of the dashboard.
2. Removed centre consul and checked clips.
3. Removed centre A/C vent.
4. Removed instruemnt panels.
5. Removed side vents.
6. Removed speakers.
All to no avail.
Finally I lubricated the bonnet latches. Guess what? Squaek is gone. It looks as if I need new rubber bonnet stoppers too.
I hope this saves someone a lot of trouble and frustration.
Old Jun 20, 2025 | 06:46 AM
good catch. Also know that failing upper shock mounts will give you a dashboard squeak as well
Old Jul 1, 2025 | 11:59 AM
CorStevens's Avatar
I have the same problem. Thank you for mentioning this. Since I have failed Welsh mounts, must eliminate the obvious.
Question: what did you use to lubricate the bonnet latches? I was thinking of synthetic grease.
In addition, check the strut to windshield frame braces. There is a TSB that some of them were not torqued sufficiently.
Old Jul 2, 2025 | 04:12 AM
Phillipw's Avatar
Default Dashboard Squeak
I used ordinary bearing grease. Its been almost a month now and still no squeak. All good.
Old Jul 2, 2025 | 01:22 PM
CorStevens's Avatar
Thank you!
FastJag42
27
Aug 23, 2023 04:39 AM
Valerie Stabenow
Jun 24, 2021 12:56 AM
K.Westra
May 6, 2020 11:22 AM
Leet8845
Nov 3, 2017 02:32 PM
jagent
Oct 14, 2015 08:36 AM
