Dead stall at stop sign.
Old Oct 13, 2013 | 07:06 AM
philhef's Avatar
Default Dead stall at stop sign.
My car has shown no signs of any mechanical issues except for a few coolant systems leak issues, which has been completely replaced.
Out of the blue yesterday, on my way home as I came up to a stop sign, my car completely stalled when I came to a complete stop. No warning lights on and no ruff engine, just a stop. I put in park and it started right back up. And doesn't sem to be having any issues since. I have noticed occasionally, after driving around town and stopping, then when I get back in and start it up, it sems to idle a bit jumpy but then goes away.
Could I have inadverntly hit my ignition key with my knee and turned off car?
Old Oct 13, 2013 | 07:50 AM
DevSpider's Avatar
I'm not a mechanic and the symptoms are not conclusive to any specific problem, so it can mean several potential issues.
Check your fuel injection system
Check your spark plugs
Check your gas filter for contamination
Old Oct 13, 2013 | 07:59 AM
ArtyH's Avatar
Talking
Don't remember what MY your cat or the mileage but this thread struck a cord with me and I intend to change mine filter ASAP
https://www.jaguarforums.com/forum/x...er-xk8-104425/
Not saying it is this, but may be worth a look, as the above was a 2005 MY its quite shocking.
Good luck with the car.
Cheers,
ArtyH
Old Oct 13, 2013 | 08:07 AM
philhef's Avatar
My car is a 2002 XK8.
It's going into the body shop for a re spray and shock work done so I'll get it looked at after I get it back.
I'm also having the trans fluid changes so maybe he can do it all at once.
I was wondering if there would be a code stored for the incident if it was mechanical.
Old Oct 13, 2013 | 09:56 AM
WhiteXKR's Avatar
If you have a recurring condition then a code is probably stored. If it was a fleeting malfunction, then probably not. In any event the codes should be checked.
Old Oct 13, 2013 | 08:28 PM
RCSign's Avatar
As written by Phil
Could I have inadvertently hit my ignition key with my knee and turned off car?
I have done that three times I'm also 6' 4" and my knees are real close to the ignition, I've hit the wipers numerous times.
Old Oct 13, 2013 | 09:21 PM
giandanielxk8's Avatar
I did this once. My sister responded with "Gian, your car's acting up. I guess it is time to junk it". I responded with "haha what? I'm keeping this car until I die. Besides, my knee hit the key by accident."
This happened to me, and I'm a pretty short fellah.
Old Oct 13, 2013 | 09:50 PM
philhef's Avatar
I realized today that I must have hit the seat position memory 2 while I was covering my inserts. My knees were a bit higher and I did it again! My knee hits the fob and turns off the car!! Ugh.
Old Oct 13, 2013 | 10:00 PM
The Coupe's Avatar
Hmmmm...I don't know. Anything is possible, I suppose, but the knee theory sounds a bit unlikely to me.
Old Oct 14, 2013 | 05:56 AM
philhef's Avatar
I'm still having it checked when it goes in for some transmission work. (New fluid, gasket, etc. )
But when I did it in my driveway, as I got out of the car, I started checking and found the seat was further up. I did feel my knee hit the key.
Old Oct 15, 2013 | 12:09 PM
itspec60's Avatar
When my car did the exact same thing I found that the throttlebody needed cleaned at the butterfly. After removing the black "coke" ring it never did it again.
Old Oct 15, 2013 | 12:20 PM
Gus's Avatar
Gus
Check the codes first!
ferraripete
Sep 12, 2016 09:02 AM
shootingbrake
Sep 23, 2015 10:54 AM
John Fox
Sep 19, 2015 07:56 PM
Tim Goz
Sep 17, 2015 09:11 AM
neckstrap
US Western
Sep 10, 2015 10:44 PM
