Do I have a Battery problem???
Old Mar 26, 2010 | 03:25 PM
brgjag's Avatar
Default Do I have a Battery problem???
Jag has been sitting a few days, got to 28 last night, car garaged (detached) went to start today and it did but while cranking the batt. gauge needle went down near the RED, real close. That can't be right?? Sign that battery is weak?
Old Mar 26, 2010 | 03:36 PM
test point's Avatar
Batteries are best tested under load at the local auto parts store with their multi-test equipment. Who knows what the Jaguar dash meters are supposed to read while cranking. Jaguar owners have no need for such detailed information.
Old Mar 26, 2010 | 04:04 PM
brgjag's Avatar
ha ha ha. Well I never "recall" it going so far to the left of center where it always sits. It was about at the white line before going into the red. With my various burps with the car of late I suspect the batt is with issue.
Old Mar 26, 2010 | 06:10 PM
Gus's Avatar
Gus
Chances are that the battery will be a future problem. You should go and get it checked! Any good battery supplier (Sears, AutoZone, Etc) will be able to do it while it is in the car.
Old Mar 26, 2010 | 09:42 PM
BobF's Avatar
Battery capacitiy drops with temperature, that's why cold temperatures kill weak batteries. Some general information.
http://www.magnacharge.com/mchg_all.htm
Old Mar 27, 2010 | 07:12 PM
hlgeorge's Avatar
You can usually tell a weak battery when you start it. It just doesn't have that quick start feel even though it starts. Mine is weak now because it doesn't get driven much in the cold weather. Warm weather is in view, hooray!!
Old Mar 28, 2010 | 09:10 PM
brgjag's Avatar
Well it's been in the garage like it always is and I have not had a slow turnign over motor since that one time after it sat for like 3 days. It has sat a few times for 2 days, once when it got down to 28 degree's but it cranked over like normal. Short in battery? Terminals on battery are clean and new looking. Where do they come out at motor? Starter and ??
Old Mar 29, 2010 | 04:11 AM
test point's Avatar
The engine compartment battery terminals are next to the two fuse panels, each a covered bolt. Have you measured the battery voltage under starter load? If it goes below 10v, even if the starter will turn the engine, the electronics get squirrely.
Also check the grounds.
Old Mar 29, 2010 | 05:18 PM
Gus's Avatar
Gus
This is for a 95xj6 & 99xk8 and it might help http://www.gusglikas.com/AutoRepairTrunkPowerAccess.htm
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
OkieTim
Sep 8, 2015 04:48 PM
mcdutch
Sep 4, 2015 03:38 AM
OkieTim
Sep 2, 2015 12:48 PM
