Do you need a VVT Tool when installing timing chains
Old Oct 1, 2010 | 09:04 PM
kdross's Avatar
Default Do you need a VVT Tool when installing timing chains
We are installing timing chains in a 2000 XK8. The alldata CD shows a procedure to check the VVT by using a special tool (part #303-654). Is it necessary to do this procedure? Is there another procedure for installing the timing chains other than the procedure stated in alldata? If so, where can I find this information?
Old Oct 2, 2010 | 05:17 AM
test point's Avatar
I didn't use any tools other than the lock down bars to do just the secondary tensioners. The FAQ Sticky above has a complete pictorial on the work.
Old Oct 3, 2010 | 05:41 PM
kdross's Avatar
Test Point. Thanks for the input. I have reveiwed the FAQ sticky and have reviewed many articles and postings on installing the timing chains. However, I do not recall ever reading anything about using the VVT special tool (part # 303-654). But the alldata CD clearing shows a procedure to check the VVT using this special tool. Does anyone have any other input?
Old Oct 3, 2010 | 07:03 PM
Brutal's Avatar
you only HAVE to have the lock down bars for the cams to hold them. You can work around everything else
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
May 30, 2021 08:13 AM
philwarner
Sep 5, 2015 10:05 AM
Sprayall
Sep 3, 2015 07:49 PM
Bcrary3
Sep 3, 2015 03:48 PM
