Door handle seal
Old Jul 26, 2015 | 02:04 PM
randyb's Avatar
Default Door handle seal
When they painted my car, they took the rubber seal off from around the door handle and you cannot buy either the seal or a door handle.
I am thinking of using RTV or something similar to replace the seal, so that the handle will stay tight.
Anybody else have this problem?
Old Jul 26, 2015 | 02:33 PM
<p>Randy - you can buy the seal - I bought a set about 18months ago.&nbsp; Let me find the part number info and I will provide - unless someone has it readily available</p>
Jandreu's Avatar
I would get a thin PC of sheet rubber and make one if the original cannot be sourced..
Old Jul 26, 2015 | 02:38 PM
<p>&nbsp;</p><p>Welsh has them -&nbsp;where I bought mine - pretty easy to replace</p><p>Welsh Enterprises, Inc - Jaguar XK8 / XKR (97-06) Body Fittings Front Doors Parts</p><p>&nbsp;</p><p>&nbsp;</p>
Old Jul 26, 2015 | 02:42 PM
clyons's Avatar
Is this what you're looking for?
Old Jul 26, 2015 | 03:45 PM
randyb's Avatar
Guy I have do the styff I cannot do, told me they did not make just the seal.
Thanks, the handle rattling was driving me CRAZY.
Old Jul 26, 2015 | 07:27 PM
Chuck Schexnayder's Avatar
I just replaced the seal (gasket) on my drivers door.
The door handle has to be removed which is quite a job. The door window has to be in the 'all the way up' position. After you do that disconnect the Bty., because if you hit or move the wrong thing in there, the power window will come down and if your hand is in there, you could loose a finger or mangle your hand. Thankfully I wasn't hurt, but I speak from experience.
The new seal is just like the old one and wraps around the handle. The handle lift (opening) part was not present when they installed the original seal and they then installed the opening mechanism which has a spring which clamps over the rap around portion of the seal.
If you replacement seal is on the drivers side, you will also have to remove the key lock, which is not that hard. It is held to the door handle by a single phillips head screw. Once the screw is removed the locking part can be removed by a half turn.
Come to think about it, this was a hell of a job. Do some reading or ask for some help from someone who did the job before. To put the seal back on like it came from the factory is not just a simple snap over thing like a rubber band. It's a zinger to do.
Old Jul 27, 2015 | 08:12 AM
White Bear's Avatar
I did this a few years ago on my 98 XK8, I seem to remember I cut one section to install it, rather than dissemble the whole door handle. My new to me 05 XKR needs one on the left side. Thanks for the reminder, I ordered one yesterday. Now it's back to the upper suspension bushing project. I noticed the top strut mounts need replacing too, bugger!
Regards,
White Bear.
Old Jul 29, 2015 | 09:16 PM
Jag#4's Avatar
Here's a set on eBay cheap.
New Left and Right Door Handle Gasket Kit for Jaguar 7837 | eBay
Old Oct 13, 2015 | 08:52 PM
randyb's Avatar
Regards,
White Bear.
Oh, you might be my new best friend!!
Old Oct 14, 2015 | 09:48 AM
Richxk8's Avatar
Just ordered a set on E-Bay, $26.50. Scheduled delivery for Tuesday the 10th. Then the hard part, from what I have read, let them set in the sun to get pliable prior to trying to install them.
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
sadepol01
Sep 11, 2015 05:26 AM
1964Daimler
Sep 9, 2015 11:28 AM
hoodun
Sep 7, 2015 07:02 PM
