Drain plug for block?
Old May 15, 2011 | 12:11 PM
DISCOSTU29's Avatar
Default Drain plug for block?
Should the block be drained when chaning the coolant? I know there is a drain point behind or above the starter but i found a socket head bolt like the one on the supercharger bleed point although a bit smaller on the other side of the block. Is this also a drain point?
Old May 15, 2011 | 01:02 PM
test point's Avatar
JTIS only displays the one drain plug which, I could not reach, behind the starter. I guess if you had a lift it would be easier.
I just drained all that would come out and refilled with a premixed 50/50 solution. That was easy but a flush would be appropriate if you are changing types of coolant.
Old May 15, 2011 | 01:20 PM
DISCOSTU29's Avatar
yeah, didnt really want to remove the starter to drain the coolant in the block.
Old May 15, 2011 | 01:50 PM
motorcarman's Avatar
There is a drain plug on the left side of the block towards the rear. You will need a 17mm hex socket wrench (allen), a long extension and a 1/2" breakover bar or 'cheater pipe' to get some leverage.
bob gauff
Old May 15, 2011 | 03:34 PM
DISCOSTU29's Avatar
awesome that must be the one I saw. I'll give that a go
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
mrplow58
Sep 15, 2015 09:58 PM
chatmanx
Sep 11, 2015 07:17 PM
