Dreaded octopus hose leaking
Old Nov 4, 2018 | 07:11 PM
Ltd's Avatar
Ltd
Default Dreaded octopus hose leaking
Well, it's my cats turn. I've ordered new spider hose, valley hoses, manifold gaskets, TB and induction elbow gaskets. Any other parts needed? Oh, and I have a couple new tools- fuel line release tools and a remote spring clamp pliers.
Old Nov 4, 2018 | 07:53 PM
stevepaa's Avatar
patience, I did mine years ago, I remember it being awkward and getting cuts/scrapes on my hands.
Old Nov 5, 2018 | 06:25 AM
Jon89's Avatar
How did you discover your leak was at the octopus hose? Could you see it initially, or did you catch it by performing a pressure test?
Old Nov 5, 2018 | 05:15 PM
Ltd's Avatar
Ltd
Default Octopus hose hosed
I smelled that unmistakable odor of cooking coolant and a small puddle on the garage floor. I could see coolant collecting in the square recesses on top the trans. All this with the motor off.
With the engine running and up to temp, I could just see a drip, drip, drip. Further examination with a mirror revealed the source, the non return valve in the octopus hose.
With 93k miles on it, it's a 98 XK8, it seems prudent to pull the intake and throttle body to get at the valley hoses. With the intake and TB out, should make things easier to get to.
JTIS wasn't too helpful for removing the intake, but there is at least one good forum write up with photos ( I think it was from Gus). I'm unsure about whether the individual injectors need to come out or the rail as an assembly but I'll figure it out.
Thanks for a great forum
Old Nov 5, 2018 | 05:26 PM
michaelh's Avatar
You only need to disconnect the fuel rails at the two connectors.
Do consider replacing the thermostat tower with an aluminium one 'while you're in there'. It's a lot easier to do with the inlet manifold out of the way.
I think this job is one of the rites of passage for XK* ownership.
Old Nov 5, 2018 | 08:21 PM
Ltd's Avatar
Ltd
New thermostat housing is done. While I'm in there, I'll replace any vacuum lines under manifold or to the throttle body.
I think I'll take plenty of photos
Old Nov 6, 2018 | 05:52 AM
Jon89's Avatar
Best of luck with the repair. This is one job that I truly dread....
Old Nov 6, 2018 | 07:36 AM
cjd777's Avatar
LTD, another while you are in there moment. Clean the bottom of the knock sensors and the surrounding area below the bolt. I lightly sanded mine with 600 after a leak in the thermostat, very corroded.
Old Nov 6, 2018 | 10:12 PM
Ltd's Avatar
Ltd
My 98 knock sensors are threaded in, the top visible from outside the manifold, appear to have the leads encapsulated in epoxy resin. I wasn't planning to disturb them . If it ain't broke don't fix it. Maybe someone can advise if these are better , worse, or the same as the ones mounted on studs.
Old Nov 7, 2018 | 08:38 AM
michaelh's Avatar
I think they changed with the arrival of the AJ27 motor. Don't know if they're better or worse, but they do share an aversion to coolant...
Old Nov 11, 2018 | 10:11 PM
Ltd's Avatar
Ltd
Just an update. Octo is done. The remote spring clamp pliers is a must do. The big leak was on the non return valve above the transmission, behind an electrical box. The 10 mm ID hose at the tee on the heater return pipe going up to the TB had fresh coolant stains. I've sourced a new one.
Thanks Jag Forums!
Ltd
MarkO1
Sep 4, 2013 09:35 AM
bluerdg
Jun 8, 2013 01:36 AM
mikeeadyjr
May 1, 2013 11:05 PM
thenaz007
Dec 6, 2011 11:31 PM
jagowner
Mar 16, 2010 06:03 PM
