Drilled, slotted brake rotor noise comments
Old Jan 27, 2013 | 06:41 AM
NikasilNik's Avatar
Originally Posted by GGG
+1
I can just about take the argument for the benefit of slots on a road car but holes - no!
Every time I have the wheels off my XK8 (usually four times a year), the holes are completely clogged with brake dust and I have to use a drill bit to clear them.
Ditto
All the best
NikasilNik
Old Jan 27, 2013 | 10:10 AM
oldmots's Avatar
I have never had holes clog. The Brembo and Hawk pads will not do this, at least not on any car I've had that uses cross drilled rotors. I can't speak for any others though.
Old Jan 27, 2013 | 06:01 PM
RCSign's Avatar
What kind of pads are they selling you over the pond that would clog your holes? (That kind of sounds obscene.) I've never have had that problem with any of the cross drilled discs on any of my vehicles. I will have to agree with Ajmevans, OldMots, and Plums, most of the engineering has been proven on the race track. Also if your not aggressively braking, the performance brakes will have a tendency to glaze, which will make them squeal. Aggressive braking will keep the glaze off.
Old Jan 27, 2013 | 06:22 PM
Mikey's Avatar
Sure does. Maxi pads are popular on this side of the pond I hear.
Old Jan 27, 2013 | 07:14 PM
enderle's Avatar
Default Holes no problems
I swapped my rotors out for cross drilled ones, no clogging and no noise. 2004 XKR w/brembo.
Old Jan 28, 2013 | 12:58 AM
avos's Avatar
Probably driving style does account for the clogging as well. I have used the brakes a lot, and had to clean out the holes many times, one of the reasons I went for plain discs now.
Old Feb 2, 2013 | 01:58 PM
Badger's Avatar
Hi folks, thought I'd relay my own experiences of brake noise.... but for the record I use normal, not drilled or grooved, EBC front discs on my XK8, with no braking issues or perceived lack of brake performance whatsoever.
My last car, a Chrysler 300c hemi, needed new front discs so I went for EBC drilled and grooved with redstuff pads, and had horrible rotor noise when braking. I cured this noise by swapping the discs side to side, so that the normal direction of rotation now had the slots drawing air in, not centrifuging it out. The noise was the grooves trying to push the pads out from their seating against the caliper carrier brackets, against the moving part of the caliper, causing them to resonate. With the discs swapped, all was quiet, as the grooves were now trying to pull the pads in against the carrier brackets, avoiding any movement or resonance. Hope this helps....?
H20boy
Dec 24, 2024 03:23 PM
Razor
Aug 28, 2019 08:34 PM
ym37tech
Feb 8, 2016 01:04 PM
Jefro
Sep 15, 2015 01:44 PM
JagLove86
Sep 6, 2015 10:36 PM
