Driver seat is stuck and will not move. Tried the usual suspects.
Old Jun 26, 2018 | 09:22 PM
RC Tod's Avatar
Default Driver seat is stuck and will not move. Tried the usual suspects.
Within an hour of getting the car home for the first time ( bought used ) my wife moved the driver seat forward to suit her and the seat stopped. Now it will not adjust, go up nor lumbar support. SO, I searched the forums here. First I disconnected the battery for 15 minutes, plugged it back in, didnt work. Then, I disconnected it again, swapped the control modules, and the driver side worked on the passenger side. Looked at all the wiring I could see, and then checked fuses with an ohm meter. Nothing, and the seat will still not move. Everything else works. Any ideas? I'd love to get the seat out to check things. I can see two torks screw per side in front. If I loosen them will I bet the seat up high enough to be able to see anything? And where are the rear bolts for the seat anyway? Seems like this is a common problem. And what size are those torks screws? Thanks!
Old Jun 26, 2018 | 09:34 PM
Orthodixie's Avatar
Make sure you check the connection socket front right side of seat. I brought mine too far forward and it died. Was about to take seat out but stuck my head under and saw the connection had pulled out just a bit. Reconnection mate all right.
Old Jun 26, 2018 | 09:44 PM
RC Tod's Avatar
Will do, what does it look like? There is a lot under there!
Old Jun 27, 2018 | 08:55 AM
Originally Posted by RC Tod
..... I can see two torks screw per side in front. If I loosen them will I bet the seat up high enough to be able to see anything? And where are the rear bolts for the seat anyway? Seems like this is a common problem. And what size are those torks screws? Thanks!
There's 2 on each rail. Follow the rails to the back and you'll see the equivalent torx fixings there. I recall the ones on my 2005 XK8 were M8. I doubt you can raise the front of the seat with the rear torx in place and not bend the rails.
xk8newbie
Nov 21, 2016 06:32 PM
Dan R
Oct 14, 2016 08:57 AM
Artigiano
May 23, 2014 02:11 AM
Plaster
16
Oct 31, 2013 03:51 PM
Kersh
Oct 7, 2009 03:48 PM
