Driver's door mystery
Old May 22, 2026 | 06:57 PM
5JAGMCLEAN's Avatar
Default Driver's door mystery
We don't drive our 1997 Xk8 during the winter. I ensure the fluids are fresh and connect a CTec battery charger. This year when I prepared her first outing the drivers window did not lower when I lifted the door handle. I thought perhaps the window was out of adjustment. I forced the door open and sat down, inserted the key and started the car. While them car was warming up decided to check the windows. The drivers window controls did not work, nada, nothing. The mirror controls did not work. The door windows were fine prior to the winter sleep and the battery stayed up. I checked the fuse in the left dash cowl and it was fine. Do you folks have any ideas for a fix?
Old May 22, 2026 | 08:07 PM
giandanielxk8's Avatar
The fuse is on the right side of the dash. Check it again. I bet your passenger door also has the same symptoms.
Old May 23, 2026 | 08:19 AM
daveb97's Avatar
Do the windows go up and down with the button if they do they just have to be reset sit in the car run the windows down hold the button till you hear a click then run it up hold the button till you hear a click do this for the other door as well then check it when you open the door it should drop a small amount if the battery was run down or removed the windows need to be reset every time the battery is removed
Old May 23, 2026 | 09:33 AM
zray's Avatar
Originally Posted by daveb97
Do the windows go up and down with the button if they do …..”
if I’m reading the OP’s post correctly he says there’s no movement at all, therefore future adjustment is not possible yet.
@giandanielxk8 mentions a good starting point : check the fuses.
Z
Old May 23, 2026 | 09:34 AM
zray's Avatar
Duplicate
Old May 23, 2026 | 09:53 AM
daveb97's Avatar
He said the windows did not drop when he lifted the door handle, this is to prevent damage to the door seal at the convertible top that is why I asked if the buttons work
he also said he had to charge the battery which is a good indication the windows lost the programing
Just a note on resetting the windows have the doors closed when doing it.
Old May 23, 2026 | 04:03 PM
zray's Avatar
not to beat the old dead horse, but halfway down the OP’s first post he says none of the buttons worked.
“….While them (sic) car was warming up decided to check the windows. The drivers window controls did not work, nada, nothing…..”
Z
GisbertJag
Sep 2, 2023 03:49 AM
Fallguy
Feb 4, 2021 02:46 PM
2006XKR
May 21, 2017 10:28 PM
doc18015
Sep 12, 2012 08:21 AM
Alwann
May 23, 2011 01:51 PM
