Drivers headlight problem
Old Oct 16, 2019 | 10:29 AM
Mike Lore's Avatar
Default Drivers headlight problem
Last week noticed my front drivers headlight was out. Checked the bulb,it's fine. High beam headlight works fine,when I switch to on with the headlight stalk in car and the dip beam flashes then goes out. Where should I start looking?
_________________
1997 XK8 (added by GGG)
Last edited by GGG; Oct 16, 2019 at 12:38 PM. Reason: Add Model & Year details from post #3
Old Oct 16, 2019 | 11:23 AM
avern1's Avatar
First a couple of things and then I will get to your problem.
1. It would be helpful if you went to the User Control Panel and added your vehicle details so we aren't guessing as to what you are working on.
2. This is the XK8 forum the link below is to the correct forum for the XJ8 you have.
https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/
The most likely problem is the bulb holder is corroded or the ground connection is corroded. Try removing the bulb and cleaning the contacts within the holder. Then follow the wires to where the ground branches off and clean the ground connection. One more thing to try is swwap the bulb with the know working one and see if the problem follows to the new location. It might be that the filament is lighting and then gets hot and opens.
Old Oct 16, 2019 | 12:26 PM
Mike Lore's Avatar
I was running out the door I apologise for not posting my year and model. It's a 1997 XK8.Thanks for the info. I'm going to go work on it. I'll let you know how it turns out.
Old Oct 16, 2019 | 01:16 PM
DavidYau's Avatar
Default Worth checking out this Youtube video
+1 to avern1’s comments.
Still worth checking out this link below to the “To The Garage” Youtube channel. John has a triology on the XK8 headlamp. Bit slow but very thorough.
https://m.youtube.com/channel/UCT2ZywCQe9dtTi2qvbQNEdQ
Old Oct 16, 2019 | 05:46 PM
avern1's Avatar
My apology Mike I based the first comments on the info in your Public Profile. The info still applies in searching for a fix.
Old Oct 16, 2019 | 11:02 PM
Johnken's Avatar
1) does it light for full 25 seconds with engine off remote control button pressed?
If yes, points to wiring at the stalk.
If no, sounds like its happening between the body processor module and the light bulb.
If yes, Does the flicker usually occur within 25 seconds with the stalk switch? If yes, it's pointing to the switch in the stalk.
2) your description of the stalk operation makes me wonder if a wire connection came lose. They are soldered to a small circuit board at base of stalk. I admit I forget where in the circuit the left and right headlights are controlled by individual wires (as I recall, there are individual fuses for each side), lose wire here usually affects both lights IME.
but here's an easy test: jiggle the turn signal stalk lights on - does it impact the issue? If so we can help troubleshoot the unsoldered wire.
BTW, do you have auto headlights? If yes does it matter if in auto or manual headlight on position?
John
Old Oct 17, 2019 | 01:15 AM
Mike Lore's Avatar
John
U
Old Oct 17, 2019 | 01:25 AM
Mike Lore's Avatar
Thanks for all the help it's appreciated. Okay so first no power lights. I took out both light assemblys,I cleaned the connections and the grounds. I reassembled them put the car in the ready to start position and now the low beams work,high beams work when I pull stalk back,but not foward and the turn signals at first,the left one was flashing quickly the right flasher was normal,I did it again and it was normal. The dip beam will flash for a split second as I turn the headlights to the on position then nothing,oh and now the right dip beam is doing the same thing but the left one isn't working. I played with the stalk nothing changed. :/
Old Oct 17, 2019 | 02:09 AM
DavidYau's Avatar
Default If you’re sure the headlamps are ok, worth checking out the indicator stalk
Check out Ajax’s 2017 thread.
See link below
https://www.jaguarforums.com/forum/x...r-stalk-94411/
Old Oct 17, 2019 | 04:14 AM
frankc's Avatar
When my headlamp/headlight stopped working it turned out to be the ballast underneath the headlamp. Will see if I can find a link for you, brb.
Old Oct 17, 2019 | 04:15 AM
frankc's Avatar
Here you go. https://www.jaguarforum.com/showthre...=1#post1179717
Stephen Clark
Oct 5, 2019 06:13 PM
Pol
May 4, 2015 01:32 PM
carelm
Oct 6, 2009 01:16 PM
