Drivers Seat Electrical Problems
Old Jan 3, 2016 | 04:00 AM
stefos60's Avatar
Default Drivers Seat Electrical Problems
I have a problem with the driver seat that doesn't work. I have changed the switch, that burned, and removed the seat module. I have not managed to move the seat, in any direction. Tried with external power direct to the motors.
So, now I don't know what to do, it's tricky to remove the seat when you can't reach the rear bolt nuts. I have ckecked the fuse - there is only one to the seat I guess?
Any suggestions?
Old Jan 3, 2016 | 05:46 AM
greverrr's Avatar
If you have checked the "LH seat ecu" fuse, now I would find your "steering column adjust switch/driver seat switchpack" fuse and check it. In my XJR it is labelled "column joystick/dr seat sw pack". Very likely culprit reading your circumstances. I don't have a schematic of your fuse boxes, but it should be labelled as I have written it out in one of the rear heelboard fuse boxes as shown on your fuse box cover in the boot. Good luck!
Old Jan 3, 2016 | 08:50 AM
test point's Avatar
You say you removed the passenger seat module but did you install the driver seat module to test that?
Here is a link to the fuse panels charts for the XK8 which is significantly different than the XJ8/R.
https://www.jaguarforums.com/forum/x...8-r-faq-33555/
Old Jan 3, 2016 | 09:00 AM
oyster's Avatar
Hi.
As far as I can see it is almost impossible to reach the bolts without moving the seat.
Fuses are in drivers side fascia fuse box:
F1 20Amp Drivers seat module.
F8 5Amp Drivers seat switchpack.
You will be able to see the numbers with a magnifying glass.
The most common problems are chafed wires underneath the seat, or broken tracks in the seat control module.
Tell me if you need pinouts for the connector, and I will see if I can find it.
Old Jan 19, 2016 | 03:52 PM
mrite04's Avatar
Any suggestions?
Have you figured out the problem with your seat yet?
runner
E type ( XK-E )
Jan 11, 2016 07:54 PM
jtfred
Jan 3, 2016 09:35 AM
Ragn0r
Jan 1, 2016 11:42 PM
Won Sub Shin
Dec 30, 2015 05:27 PM
NDW
Dec 29, 2015 07:34 AM
