Drrrr! Rocker rot!
Old Feb 1, 2020 | 12:06 AM
Timeisrelative's Avatar
Default Drrrr! Rocker rot!
So I went to check my lug tightness since I had my wheels road force balanced, and I noticed that my rocker right in front of the right rear wheel finally succumbed to the Pennsylvania roads winter treatments. I started poking at it and yes it was pretty bad. I’m no professional, but I’ve done some repairs before soI decided to make my own patch panel by hand, got it pretty close, and started putting it together when it started raining. Drrrrrrr! Hopefully I’ll be able to get it finished this weekend!
Old Feb 1, 2020 | 02:11 AM
XKR-DAY's Avatar
This is a big problem in the uk, and a frightening one at that !..
I'm facing similar repairs to my sill/rocker's in the near future.
Old Feb 1, 2020 | 03:34 AM
DavidYau's Avatar
Default Damn Tin Worm is global
Well I feel your pain. I had a rust problem exactly at the same location. See my recent thread below for details.
https://www.jaguarforums.com/forum/x...ahrain-221142/
Old Feb 1, 2020 | 09:29 AM
Yes I did see your post on the repair. I guess it's a global issue 😟
Old Feb 2, 2020 | 10:34 AM
Well went out to finish today and as soon as I started it started a REALLY wet snow. Argh! Also probably going to have to cut higher due to as soon as I strike arc on a couple of spots, the factory metal disappears. Drrrrrrr! It looked, felt and sounded solid, but it must be a little bit thin. Add into the fact of laying on my side and having wet snow and a couple of small spalds going down my ear. I decided to give up for the moment. Smh
Old Feb 2, 2020 | 11:12 AM
giandanielxk8's Avatar
This is scary... P.O. installed the 2005 rocker panels on my car. I think I should remove it and check.
Old Feb 2, 2020 | 11:16 AM
Yeah it's always scary when stuff is covered. Sometimes it's ok, other times you find Swiss cheese
Old Feb 2, 2020 | 11:42 AM
I'm hopeful that since my car has absolutely zero rust anywhere else, even the exhaust, that it is probably fine.
Old Feb 2, 2020 | 12:02 PM
steven300's Avatar
this is a lot of work to keep rust from coming back,but what I do in the American great lakes rust belt is flood area's with rustoleum paint.you'll have to remove inside panels for access but it doe's a great job.i paint doors [inside seem 4 inches],flood over rear wheel wells and front 1/4s,and plug all drain holes under rocker then fill rockers to top with paint,around 4 gallons then drain back into emty cans.this is allot better than rustproofing cause it gets into everything.P.S.i use a cardboard gutter,steve
Bill Paterson
Oct 31, 2019 08:19 PM
Hex Type
Oct 6, 2019 08:05 PM
CleverName
US Northwest
35
Sep 28, 2019 11:27 AM
LTracey
Apr 30, 2019 11:08 PM
NoScurdyJags
May 18, 2017 07:05 AM
