dsc fault/ engine system failure
Old Dec 18, 2013 | 09:57 PM
jnccarney's Avatar
Exclamation dsc fault/ engine system failure
first the dsc fault shows on the lcd then engine system failure then it goes into limp mode. i saw something about cleaning something and now cant find it
HELP!!!
Old Dec 19, 2013 | 03:43 PM
robiwhan's Avatar
need more info on driving conditions recent repairs mileage etc...
Old Dec 19, 2013 | 05:48 PM
jnccarney's Avatar
HELP!!!
Sorry, its an xk8 2005 4.2 litre engine
It drives great until it warms up. It seems like it happens when slowing like coin around a corner or coming to a stop sign or just decrease speed
Old Dec 19, 2013 | 09:21 PM
clyons's Avatar
You've posted in the X-Type forum - you'll get better help in the XK8/XKR forum XK8 / XKR - Jaguar Forums - Jaguar Enthusiasts Forum.
This thread might help https://www.jaguarforums.com/forum/x...003-xk8-87029/
Old Dec 20, 2013 | 12:17 AM
jaguarxfv8's Avatar
Default Might have an answer !
Hi I had the same trouble with my xf, and it was to low voltage on the battery ! Might want to check this out first it's less expensive !
it could also be related to the throttle body ! it can be dirty or the sensor can have a problem. but if you want to check it clean it fist it might just be that.
anyway hope you resolve your problem !
Old Feb 7, 2014 | 06:53 AM
jnccarney - I've moved this from the x-type forum to the XK8/XKR section for better response to your issues. Also take a moment to visit the New Member section and post an intro.
regards,
Steve
Old Feb 7, 2014 | 11:00 AM
With any powertrain fault, the first action in troubleshooting is to get the codes read. Without that, the possible causes are speculation rather than diagnosis.
Forcedair1
Sep 8, 2025 01:57 PM
D.K
Dec 10, 2023 02:05 AM
scottatl
Sep 4, 2015 08:08 PM
pocketrocket
Sep 3, 2015 07:44 PM
OkieTim
Sep 2, 2015 12:48 PM
