dsc fault/ engine system failure
first the dsc fault shows on the lcd then engine system failure then it goes into limp mode. i saw something about cleaning something and now cant find it
HELP!!!
HELP!!!
It drives great until it warms up. It seems like it happens when slowing like coin around a corner or coming to a stop sign or just decrease speed
You've posted in the X-Type forum - you'll get better help in the XK8/XKR forum XK8 / XKR - Jaguar Forums - Jaguar Enthusiasts Forum.
This thread might help https://www.jaguarforums.com/forum/x...003-xk8-87029/
Hi I had the same trouble with my xf, and it was to low voltage on the battery ! Might want to check this out first it's less expensive !
it could also be related to the throttle body ! it can be dirty or the sensor can have a problem. but if you want to check it clean it fist it might just be that.
anyway hope you resolve your problem !
jnccarney - I've moved this from the x-type forum to the XK8/XKR section for better response to your issues. Also take a moment to visit the New Member section and post an intro.
regards,
Steve
regards,
Steve
scottatl
Sep 4, 2015 08:08 PM
