DTC Code reads "NA"
Old Sep 12, 2016 | 02:44 PM
PaulsXK8's Avatar
Default DTC Code reads "NA"
Hi guys. 2003 XKR with rebuilt 4.2. Check engine light on. When I use my scanner come up with "NA 01/02". I know 01/02 is for two times running. What does the NA indicate? The gentleman I bought it from stated it had a bad O2 sensor but I would think that would show up (No code for that only the NA and typical P1000). Any help would be appreciated. Thanks
Old Sep 12, 2016 | 03:16 PM
avern1's Avatar
Have you tried taking it to one af the auto parts stores offering free scans. I would try a different scanner. Sounds like something is communicating with yours.
Old Sep 12, 2016 | 07:57 PM
motorcarman's Avatar
N/A normally means Normally Aspirated?
It could also mean North America?
bob
Old Sep 13, 2016 | 01:48 PM
Originally Posted by PaulsXK8
Hi guys. 2003 XKR with rebuilt 4.2. Check engine light on. When I use my scanner come up with "NA 01/02".......
NA in English is usually Not Applicable so your scanner is suggesting Not Applicable to 2001/02 MY.
You have a CEL so there must be code(s). As has been suggested, try a different code reader / scantool. It's likely the one you're using isn't compatible.
Old Sep 13, 2016 | 02:29 PM
brgjag's Avatar
If you have (or anyone reading this) Android phone get the Torque Pro app from the app store and from Ebay an ELM327 blue tooth reader. They you can read your codes on ANY OBDII car. The app is pretty handy. Costs about 10 bucks or so to get these things.
Old Sep 14, 2016 | 05:21 AM
jamdmyers's Avatar
Not sure what scanner you are using but ensure it's set for at least ISO-9141 and CAN protocols
Old Sep 15, 2016 | 02:45 PM
PaulsXK8's Avatar
Default Scanner Brand
I am using a Car-Diagnostic-Scanner-Tool-U480-CAN-OBDII-OBD2-Memo-Engine-Fault-Code-Reader ISO 9141,J 1850 PWM,J 1850 VPW, KWP 200 ISO 14230-4. C.A.N( Controller Area Network).
Old Sep 16, 2016 | 01:55 AM
JagV8's Avatar
Which apparently is nowhere near as good as a cheap elm327... maybe just get an elm
Old Sep 16, 2016 | 03:14 AM
+1 to the Elm 327 / TorquePro approach.
This will only read Powertrain (Pxxxx) codes but is as much as is needed for most faults which will trigger the MIL (CEL).
I'm 2000 miles from home at the moment and that's all I'm carrying with me reasoning that if it's anything more complicated goes wrong, I'll not be fixing it at the roadside!
Old Sep 16, 2016 | 02:06 PM
PaulsXK8's Avatar
Default Update
Took the car to my mechanic. His $2000 code reader stated P1646 Linear O2 Sensor Control Chip (Bank 1)
Old Sep 17, 2016 | 01:52 AM
JagV8's Avatar
The $10 elm327 also pulls that code...
foxbottom
Sep 11, 2016 09:01 AM
Rozza
Sep 9, 2016 02:22 AM
dspguitar
Sep 7, 2016 07:39 PM
haroldpeacocksr
Sep 1, 2016 10:02 AM
susu
Aug 23, 2016 11:09 PM
