Easy Way to Get to Back Thermostat Bolts
Old Feb 2, 2020 | 12:49 PM
srpope80's Avatar
Default Easy Way to Get to Back Thermostat Bolts
Hey guys and gals, I just wanted to share the easy way to get to the rear thermostat bolts on an XK8. They are super accessible once you've completed the right steps.
​​​​​​​This this is obvious sarcasm for those that are about to jump in and tell me to use a crows foot or something along those lines. I'm tearing everything down to replace it all at once so I'll have many miles of freedom ahead. 😂
Old Feb 2, 2020 | 01:08 PM
giandanielxk8's Avatar
Hahaha
Instructions unclear, transmission is now on the floor.
All kidding aside, change that thermostat housing for a metal one that won't crack.
Old Feb 2, 2020 | 01:10 PM
srpope80's Avatar
Yes I'm doing the metal thermostat housing, the valley hoses, the octopus hose, timing chains and tensioners, valve cover gaskets, water pump, all cooling system hoses, and new intake manifold gaskets.
This has kept me busy for a little bit.
Old Feb 2, 2020 | 02:13 PM
GordoCatCar's Avatar
This little gadget works like a champ!! The tool is used to remove the two rearward 8mm bolts securing the T-Stat housing to the engine block. The front two bolts may be accessed using a ¼” drive and swivel; but the rear two bolts have limited access.
Use Vice Grips - The bent-wrench should be used in conjunction with a needle nose vice grip, and another regular style vice grip twisting the first.
File Type: doc
Old Feb 2, 2020 | 04:04 PM
michaelh's Avatar
If it's not already on your list, change the coolant outlet pipe (AJ85885) while you're in there. Not horrid expensive and you get a shiny new coolant temp. sensor for free...
Old Feb 2, 2020 | 04:45 PM
What does it take to bend a wrench that much?
Old Feb 2, 2020 | 05:08 PM
MikeAlford's Avatar
You just need to get it cherry red! Decent propane torch should do it.
Old Feb 2, 2020 | 10:14 PM
Yep a butane bottle, or even propane, a vise and hammer it over easy.
Cambo
Oct 14, 2025 01:51 PM
srpope80
Mar 14, 2019 10:11 AM
cjd777
Jun 13, 2017 08:54 PM
graham11
Feb 4, 2014 06:36 PM
JagYour
Mar 5, 2011 07:13 PM
