ECM module compatibility?
Old May 2, 2018 | 10:05 AM
ClickCO's Avatar
Default ECM module compatibility?
I have a 1998 XK8 convertible.
Is the ECM LNC1410AF/001 interchangeable with a LNC1410BB unit?
Thanks in advance.
Old May 2, 2018 | 10:38 AM
RJ237's Avatar
I don't think so. The early ECU tends to fail due to capacitor leaks, but they can be rebuilt. What codes do you have?
There are several repair services, one of which is ASI.
http://www.autoecu.com/
Old May 2, 2018 | 07:29 PM
avern1's Avatar
+1 on RJ237's advice. Have youra rebuilt. An AF suffix would be an older version and not a replacement for a suffix BB. Even if you can find one that matches it will still have to go to someone who has the software to program it to your cars network. They aren't plug and play they have to be programmed.
Rebuilding yours saves all of the reprogramming.
Old May 2, 2018 | 07:48 PM
michaelh's Avatar
LNC1410AF isn't listed in JEPC for any 98 XK8 VIN, although there are ads on the bay for the XJ8.
Also curious to know what codes you're seeing for the BB (as in mine)?
Mike
Old May 3, 2018 | 10:19 AM
ClickCO's Avatar
Thank you for your quick response.
The LNC1410AF/001 is from the sticker in the boot area of my 98 XK8. it is a manufacturer label, so I would guess the JEPC database needs updated, (just a thought).
I did not have any codes prior. My 98 XK8 would just not start. I checked all the grounds, relays and fuses. Still no start. Starter has been off and tested as a good starter. I also replaced the the 12v battery with a new one, and replaced the battery in the key fob. After that, none of the electrical comes on, with the exception of a red light on the oil gauge, a red light on the amp gauge and a red light at the shift console. I was wondering if something in the ECM went out.
I am scratching my head on this. ?????
Old May 3, 2018 | 11:30 AM
avern1's Avatar
The sticker in the boot is the VCATS. It lists the module numbers and versions that are compatible with your vehicle when looking for replacements. You state you have a not start condition.
Does that mean cranks over but won't start? Or turn the key and get nothing. The trouble shooting is different for each condition.
Let us know and maybe we can help you get it fired up. Any background info will help. Stored for awhile? Dead battery? Recent repair efforts? Recent symptoms?
Old May 3, 2018 | 12:30 PM
RJ237's Avatar
Also, it's time for a cheap code reader, then post the codes here.
Old May 3, 2018 | 01:02 PM
ClickCO's Avatar
Here is the original post/threads about the no start/electrical issues. The car had not start issues when I purchased it from the previous owner. She did not know what was wrong, other than there was something loose in the boot.
https://www.jaguarforums.com/forum/x...oblems-200608/
Old May 3, 2018 | 06:31 PM
michaelh's Avatar
Sorry, I had this the wrong way round:- I thought you were looking to replace a BB with the AF. As Vern says, the boot sticker is the VCATS label and the code on your ECM should match that, irrespective of whatever JEPC shows.
There should always be +12V on the brown and black (good colour choice by Jaguar here) wires at the starter, and the White/Red should show +12V when the ignition key is in the 'crank' (iii) position.
Member Gus has compiled a no-start guide for our cars. It's available here:
JagRepair.com - Jaguar Repair Information Resource
We're not quite there yet as I suspect that one or more of the power bus lines isn't energising for some reason, but it's an invaluable guide to keep in your toolbox.
Does the radio work with the ignition at position i (aux on)?
Do you get the instrument panel lights self-test sequence when switching the ignition on (position ii)?
Old May 4, 2018 | 12:20 PM
ClickCO's Avatar
No, the radio does not work. The instrument panel lights do not work either. Occasionally, I will get the overhead interior lights (on the windscreen) to come on, but usually not. The 12v battery is new and charged.
Old May 4, 2018 | 04:00 PM
michaelh's Avatar
OK,
Looks like you some power to some places some of the time. Possibly no codes as the data link connector might also be without.
I'm wondering what caused the 250A fuse to blow in the first place. It's a fairly serious short-circuit
Do check that the inertia switch hasn't tripped if you haven't already, although that wouldn't kill the radio etc.
Do the sidelights work?
Read through Gus' guide, and then arm yourself with a multimeter and check for 12V at all of the fuseboxes as Gus suggests. Flip the rubber cover off the stud connector in each box and confirm 12V between it and ground.
If they all check out then it's on to the relays and ignition switch circuits.
Old May 5, 2018 | 03:10 PM
ClickCO's Avatar
I don't know what cause the 250A to blow. It blew prior to my ownership. The previous owner did not know either. There was an after market DVD player installed. Perhaps that may be a part of the causation? I did check the inertia switch. In answer to your question, the sidelights don't work. I will read Gus' Guide. TY
vincent661983
Apr 10, 2018 10:18 AM
mello12u
Mar 29, 2015 06:01 PM
juliovega914
May 23, 2014 09:58 PM
b72hugh
Jul 14, 2013 09:31 PM
b72hugh
XJ XJ12 ( X305 )
Jul 13, 2013 11:48 PM
